How to remove existing sub & speakers from levin rear sh
Postby softlad » Sat Sep 21, 2013 12:31 pm
Anyone know the correct procedure for taking out the Super live Sound System Sub & speakers from the rear shelf of a Toyota Levin?
It all fixes in from above the rear shelf, the main problem I have is how to remove the full shelf one piece speaker grill that covers everything up without destroying it.
I've levered it with trim removal tools but nothing popped so it appears to be more than just clip fixed ????
Thanks in advance
softlad
Postby RobertC » Sat Sep 21, 2013 2:50 pm
so you have removed the rear seats? and the clips along the front edge of the parcel shelf?
Once you have done that there are clips around the back edge of the parcel shelf, to remove lift up the front edge of the parcel shelf and pull forwards.
MRAE111 wrote:ok thanks guys but wen u dont have trmpets i think the air flow quickeer into the throttle bodies
RobertC
Postby softlad » Sat Sep 21, 2013 3:49 pm
RobertC wrote:so you have removed the rear seats? and the clips along the front edge of the parcel shelf?
I hadn't removed them as i was thinking the speaker cover would come away on its own.
What you are suggesting is the whole of the parcel shelf plastic cover has to come out, not just the speaker cover
softlad
Postby RobertC » Sat Sep 21, 2013 4:39 pm
Yes remove the whole parcel shelf, the covers are held in by plastic pins that go through the parcel shelf and have a circular clip pushed onto them.
RobertC
Users browsing this forum: Bing [Bot] and 41 guests
