4k over heating
4k over heating
Postby slighty_looney » Mon Nov 25, 2013 7:17 pm
Hey guys
My father owns a kp61 its got a original 4k done 150000km all factory I recently replaced the thermostat because on the open road it would start getting hot. It didn't fix it
So it only really gets hot on the open road (90km plus)
The fan is working
Thermostat is new
The radiator looks abit poked but not sure if its the issue
Any ideas guys
Cheers[/i]
FC3S
Robinson Steel Fabrications
Current Ride: 88 rx7
Project: viewtopic.php?t=88412
Discussion: viewtopic.php?t=88413
slighty_looney
Postby Bling » Mon Nov 25, 2013 7:39 pm
Radiator would be my first suspect. Not all that promising if you think it's poked... It might just be clogged up with rust.
Postby Vertigo » Mon Nov 25, 2013 8:01 pm
BHG
TVIS just kicked in, yo!
Vertigo
Postby Crucible » Mon Nov 25, 2013 8:19 pm
When its upto temp, feel top and bottom radiator hoses they should both be hot. If the bottom one is noticably colder it has a flow problem.
If you have fitted a new thermostat the radiator wll need removing and rodding. It can also be a waterpump impeller but generaly it will boil over straight away if that is the case.
Im presuming the system is holding pressure with no leaks?
Crucible
Real Life Mechanic
Postby wde_bdy » Mon Nov 25, 2013 8:37 pm
Vertigo wrote:BHG
This ain't no M series, K series will run for years with a BHG. Barely worth fixing. :lol:
TK test will rule it in or out though.
Callum
wde_bdy
Postby evil_si » Mon Nov 25, 2013 9:25 pm
Blocked radiator
evil_si
Postby slighty_looney » Tue Nov 26, 2013 11:42 am
Cheers guys yeah on temp both hoses are hot its doesnt over heat sitting there or driving round town just open road driving
FC3S
slighty_looney
Postby Crucible » Tue Nov 26, 2013 3:15 pm
Feeling hoses is a quick check, it maybe still partially blocked an not giving adequate flow.
Crucible
Real Life Mechanic
Postby andyztouring » Tue Nov 26, 2013 3:43 pm
Check the impellor in the water pump,had 4K many years ago with that problem.A new water pump and problem sorted.But have the radiator checked ,may need rodding out or recoring.
andyztouring
Postby slighty_looney » Tue Nov 26, 2013 5:47 pm
Yeah going to sort radiator next week ill update once its done cheers guys
FC3S
slighty_looney
Postby allencr » Wed Nov 27, 2013 1:15 pm
LOOK at the tops of the tubes! Mucked up, mineralized, clogged with bits of smegma, or look free & open & clean & clear? 6 or 7 should be visible, any more then 2-3 clogged means they need cleaning out. Compressed air & garden hose work fine for loose stuff.
Bottom hose should be significantly cooler then the upper.
Rev the engine after the thermostat opens and coolant will really puke out the filler when the tubes are clogged.
allencr
Postby edwagon » Thu Nov 28, 2013 11:20 am
andyztouring wrote:Check the impellor in the water pump,had 4K many years ago with that problem.A new water pump and problem sorted.But have the radiator checked ,may need rodding out or recoring.
+1 on the water pump
edwagon
Re: 4k over heating
Postby slighty_looney » Mon Dec 09, 2013 9:47 am
Hey guys
Just a update it was the radiator that was poked. Ended up buying a alloy civic radiator. Remounting the factory fan and modified the radiator to suit the outlets on engine. Worked a treat. This how it looks now
FC3S
slighty_looney
Users browsing this forum: Bing [Bot] and 361 guests
