C56 into an AW11
C56 into an AW11
Postby Crown » Sun Jun 19, 2011 6:05 pm
Anyone done this?
Need to know what axles to use???
Crown
Postby headshotnz » Tue Jun 21, 2011 10:21 pm
We are about to do this, picked up my 2nd c56 lsd from pickapart for $102.50 :)
Current: UCF20 NZ New LS400,
(Current project) Gen II SW20 Turbo (MR2 v0.5Beta currently in the works)
Previous: Ae101 trueno (S/S), ST185 Group A, Accord with adjustables and H22a certed. SW20 (ct20b, blitz ecu) Uzz30, ae101 s/s 20v c56(-04c;) ) lsd, ae100 beast 5afe(for maximum horsepowers)
headshotnz
Postby crispy'86 » Tue Jun 21, 2011 11:21 pm
I'd imagine it'd be a similar exercise to converting the c52 out of a front drive corolla into an aw11. From what i remember c56 and c52 linkages look the same. May need to mod ae101 axles or run the inner cv's off one
crispy'86
Postby CelicaGT8 » Thu Jun 23, 2011 6:11 pm
headshotnz wrote:We are about to do this, picked up my 2nd c56 lsd from pickapart for $102.50 :)
Want to double your money?
CelicaGT8
Postby CXGPWR » Fri Jun 24, 2011 12:19 am
To do this you will need to cut the c56 To allow the shift linkages to operate on the aw11, easily done with a disc grinder with thin blade & aslong as you know where to cut and are good with the grinder you'll be sweet, you can use the same axles from the aw11 if it was equipped with a c52 standard. Only need to change axles if you are changing from auto or from e series box(supercharged aw11) as these box's run different axles.
Hope this helps
CXGPWR
Postby Mr Revhead » Fri Jun 24, 2011 9:57 am
Some where in google land there is a good pictorial how to on this.
Postby Mr Revhead » Fri Jun 24, 2011 10:02 am
Re: C56 into an AW11
Postby 85AW20v » Mon Oct 06, 2014 9:58 pm
See ya
Simon
85 MR2 20v
85AW20v
