i need more boost!
i need more boost!
Postby flynboy » Thu Jun 10, 2004 7:35 pm
hmm well i own a nissan bluebird maxima with a turbo, the thing is ist not boostin much at all an i was wondering if i cud get more boost outa it??? my mate tryed puttin a T peice in but he wasnt sure about it so that failed, but if any one knows plz let me know, :D
Flynboy... what was i thinking back in 2004 haha..
flynboy
Postby Lloyd » Thu Jun 10, 2004 7:55 pm
Boost controller maybe? Did it to my mates bluebird and it worked a treat
Postby flynboy » Thu Jun 10, 2004 9:02 pm
i dont have one and i wouldnt know how to connect one up,?
flynboy
Postby Lloyd » Thu Jun 10, 2004 9:09 pm
Find your wastegate actuator hose, cut it in half and put the boost controller in the line. It bleeds a certain amount of air off so your wastegate opens at what it thinks is normal pressure when your turbo is in fact making more boost than that.
Postby 1598cc » Thu Jun 10, 2004 10:14 pm
Just be careful with your fueling tho.. Dont want it running lean
Unsure if those cars have a boost cut in them?
1598cc
Postby hazard80 » Thu Jun 10, 2004 10:16 pm
can you say: free boost? :twisted:
hazard80
Postby flynboy » Thu Jun 10, 2004 10:55 pm
HRT wrote:Find your wastegate actuator hose, cut it in half and put the boost controller in the line. It bleeds a certain amount of air off so your wastegate opens at what it thinks is normal pressure when your turbo is in fact making more boost than that.
only if i knew wot i was playing with,any one cud help me one day? :P
flynboy
Postby badidas » Thu Jun 10, 2004 11:48 pm
ill do it for $50 i made one out keg tap once lmfao
find a cheep controller or go get me a keg :wink:
1989 mazda bongo aka [BNGBUS]
badidas
Postby Lloyd » Fri Jun 11, 2004 12:04 am
lol
Alright, here we go. This is a turbo. Left side is where the exhaust stuff goes, the right is the intake (compressor side). The big long rod bit with the thing on the end on the right is your wastegate actuator. If has a vacuum hole that goes tot he compressor side if the turbo. When you make a certain amount of boost this causes that rod to move and allow some of the exhaust gases to bypass the turbo so it doesn't keep speeding up basically. This limits how much boost you make.,
A boost controller (like those down the bottom) simply goes on the hose from the compressor side of the turbo to the wastegate actuator. It lets a certain amount of the boost pressure that would normally go to the actuator just bleed away. So when you're making 12 psi at the compressor side of the turbo and the wastegate would normally open, you are now allowing a certain amount of pressure to leak away and the actualtor only gets a partion of that pressure. So to make the wastegate open you need to put a lot more air in there. So when you're making say 15 psi at the compressor side the wastegate now sees the 12 and start to open.
Numbers are all just for show, but you get the point. To install the boost controller you just need to find this hose (should be the only one to the actuator I think, and if not then just see where it goes), cut that hose and put the controller in (hose just pushes on each end, or hoseclip it on).
I hope that sort of explains it. Someone correct me if thats wrong, thats how I've come to understand things.
Postby Undertow » Fri Jun 11, 2004 12:09 am
There should be a small rubber hose. Pull it off.
トヨタソアラドリ
http://www.geocities.com/weareallameric ... bobis.html <---the greatest website in the world.
CT12s are shit.
Undertow
Postby flynboy » Fri Jun 11, 2004 6:06 pm
hmmm any one in my area that cud help me out with this??
undertow: u sayin for me to pull da rubber hose off or is that with wot hrt said?
flynboy
Postby badidas » Fri Jun 11, 2004 7:19 pm
i live just around the corner ! off weatherly
badidas
Postby flynboy » Fri Jun 11, 2004 7:44 pm
true that? wot car u drive or name i might of seen u around b4 m8?
flynboy
Postby badidas » Fri Jun 11, 2004 7:53 pm
blue ae82 rolla bumpstoped black/mirror tints
i know nick too
badidas
Postby flynboy » Fri Jun 11, 2004 8:15 pm
hmm i dont think ive seen it mayb i dont know cuz, wot ur name ?
flynboy
Postby badidas » Fri Jun 11, 2004 8:46 pm
reconise it now ???
badidas
Postby flynboy » Sat Jun 12, 2004 11:38 am
hmmm cant say i do
flynboy
Postby flynboy » Sat Jun 12, 2004 5:30 pm
well hmmmmm i did the T peice an it worked, it lags heeps under 3 thous revs then BANG it goes but now i think i killed it, mayb im wrong or its cum lose or somethink? but i see oil :cry: .......
flynboy
Postby badidas » Sat Jun 12, 2004 6:27 pm
dude did u put a t peice and then a boost controller off it of just a t peice off the hose !!!!
badidas
Postby Farmer_dave » Sun Jun 13, 2004 10:10 pm
well hmmmmm i did the T peice an it worked, it lags heeps under 3 thous revs then BANG it goes but now i think i killed it, mayb im wrong or its cum lose or somethink? but i see oil .......
Damn that dont sound good!!
Sometimes a little bit of info is too much, gets you into trouble!!
My Profile:
Now updated with a new pic
http://toyspeed.blakjak.net/profiles/profile.php?id=201
1997 Caldina GT-T
Farmer_dave
