Turbo sizing for 4agze to 4agte conversion
Postby beeker » Sun May 28, 2006 11:27 am
I've made the call to Turbo the 4agze in the AE86. As its a Targa competition car, i'll probably buy a new turbo so its nice and reliable. Remember Targa has lots of on/off throttle and your guessing the whole time about whats comin up around the corner, thens bursts of speed and then on/off throttle again.
The wants:
> I want Lots of torque
> Quick to Spool, a must
> Minimal lag, a must
> Good throttle response
250hp is acceptabe
Someone has suggested a T25g. Along similar lines I'm thinking a mid to small garrett ball bearing, but i'm not really up with specifics here.
What would be recommended ? Also what about wastegates ? Internal/external, size ?
thx in advance.
94 DC2 Integra Race Car
02 M3 Race Car build
06 RS4 Avant
beeker
Postby bluemaumau » Sun May 28, 2006 12:34 pm
t25 sounds good but i thought they werent ball bearing?
(off a ca18)
Postby Stu- » Sun May 28, 2006 12:39 pm
TD05h. Stupidly reliable and make really usable power.
Project Thread
Stu-
Postby Steve123 » Sun May 28, 2006 1:52 pm
GT28R or RS 0.64A/R
Steve123
Postby beeker » Sun May 28, 2006 4:23 pm
Steve123 wrote:GT28R or RS 0.64A/R
Somone told me that the T28 would be too laggy for an on/off throttle style of driving ?
06 RS4 Avant
beeker
Postby Steve123 » Sun May 28, 2006 11:20 pm
Should be ok as long as you keep the revs up. If you fit a smaller turbo you'll need more boost. GT2554R is next size down and is only rated at 240hp.
You could also try a VF24 or similar. PITA to fit though
Steve123
Postby Caveman » Mon May 29, 2006 1:03 am
Tha Shz is using a GT25R. ball bearing garrett turbo, rated to 280HP (or 250HP, cant remember). Should be right up your alley. Ralatively cheap too.
td05 might be a little big for 4age and targa. So would vf22 STI turbos.
Im using a vf8, rated to 270HP but I imagine a little lagier than the GT25R. They use a pretty big ex housing (same as the STI turbos) but as a trade off have really good top end
Caveman
Steve123 wrote:Should be ok as long as you keep the revs up. If you fit a smaller turbo you'll need more boost. GT2554R is next size down and is only rated at 240hp.
Oh 240HP for the gt25r. There you go 8)
Caveman
Postby crnkin » Mon May 29, 2006 6:50 pm
Did we pop round to your house and drop the gearbox off?
From what you were saying, about targa being alot of 2nd and 3rd gear, im thinking you are quite high in the revs.
When your racing, your always up in high revs, so the spool up time is not so much of an issue. Its like a drag racer saying "dur i wanna small turbo for wicked spool up" when your only spooling up for like .5 seconds (if not running antilag)
Two examples of turbos:
My 4agte runs a vf10. Hits 7psi (full boost) by 3400 ish on a bad day and then pulls VERY hard all the way to 8k.
My friends 4agte runs a m10 t25 (what your suggesting). Hits full boost by bout 2800ish, very fast spool before then, but reaaaaaaally runs out of juice in the higher revs, the spool is noticably quicker, but the car is noticably slower overall. (he does have poos gear ratios but still)
Now aiming for 250hp is sweet. You can get that kind of power very very easily on stock 4agze engine with a turbo. Your probably looking at 10psi boost on a BB t25 to hit 250hp. but can safely run 15, so id be up around there, at around about 280hp at the fly.
Remember there are lots of trims in the t25, and lots of varying qualities of them too, Some are rooted and some are like new.
If I were you id probly be looking at a BB t25, a vf8/10, or a t28 from s14/5 with the smaller ex wheel.
One thing I can tell you for sure is, your gonna love the 4agte, and NEVER turn back
deaf_homo "currrently yes"
crnkin
Postby strx7 » Mon May 29, 2006 7:31 pm
a key thing to remember is that for an application like targa, when you can see stages of upto 40km, too smaller turbo will start to harm your engine due to it not being able to expell exhuast heat. If you're not affraid of spending the $$ for the right set up then ball bearing is the way to go
Postby matt dunn » Mon May 29, 2006 8:10 pm
I have had a few turbo setup on my 20V turbo circuit car,
and after running a couple of T28's and Hybrids, and spending a lot of money, I wish i had just gone and bought a new BB Turbo.
Matt
Postby beeker » Mon May 29, 2006 8:30 pm
strx7 wrote:a key thing to remember is that for an application like targa, when you can see stages of upto 40km, too smaller turbo will start to harm your engine due to it not being able to expell exhuast heat. If you're not affraid of spending the $$ for the right set up then ball bearing is the way to go
What model would you recommend ?
06 RS4 Avant
beeker
matt dunn wrote:I have had a few turbo setup on my 20V turbo circuit car,
Matt
bb = ball bearing ?
06 RS4 Avant
beeker
Postby beeker » Mon May 29, 2006 8:43 pm
crnkin wrote:Did we pop round to your house and drop the gearbox off?
haha, small world.
So what about wastegates ? internal ? external ? size ?
06 RS4 Avant
beeker
Postby flygt4 » Mon May 29, 2006 9:05 pm
i run a vf24 , i would use something else if i was doing it from scratch. makes decent power tho, 250hp is a breeze. boost is a bit slow to build tho , in the low to mid 4000's for full boost , but i also have a bit lower compression than standard.
id say get yourself a nice new internally gated ball bearing jobbie in approx t25 sized trim , maybe slightly larger.
flygt4
Postby strx7 » Mon May 29, 2006 11:06 pm
I'd also look at running W.I especially on the longer stages, what EFI system are you running? are you running something that can trigger an auxilary feature based on intake temperature?
Postby matt dunn » Mon May 29, 2006 11:48 pm
beeker wrote:
bb = ball bearing ?
Yes.
Postby Crucible » Tue May 30, 2006 12:45 am
I just finished building my GTE, has a .70 a/r exhaust and I dont see full boost till about 4-5k, boost gradually builds then Whammo :lol: , yah Gotta love the top end pull on the big T3/4's, but then again I built for topend power!
Crucible
Real Life Mechanic
Postby crnkin » Tue May 30, 2006 12:01 pm
If youve got the money, which i 'think' you do, id go straight to garret, maybe www.cheapturbo.com, and buy a gt28bb series turbo. Supposedly the GT2871RS bb turbo, by garret, provides the best possible a/r's for spool and power on a 4agze, theres a couple of people in the USA who recommended this turbo to me, and at 25psi its good for 400hp atw, with full boost before 4g. Only problem for me is i make 20 bucks a decade and the turbo is about 1700 dollars.
Internal wastegates are fine, externals sound cool and flow alot of gasses but most new bb turbos are up around the 35-38mm mark for their internals anyways, so no need for external.
Nice audi ;)
crnkin
Postby crnkin » Tue May 30, 2006 12:07 pm
crnkin
