Steve123 wrote:Should be ok as long as you keep the revs up. If you fit a smaller turbo you'll need more boost. GT2554R is next size down and is only rated at 240hp.
You could also try a VF24 or similar. PITA to fit though
strx7 wrote:a key thing to remember is that for an application like targa, when you can see stages of upto 40km, too smaller turbo will start to harm your engine due to it not being able to expell exhuast heat. If you're not affraid of spending the $$ for the right set up then ball bearing is the way to go
matt dunn wrote:I have had a few turbo setup on my 20V turbo circuit car,
and after running a couple of T28's and Hybrids, and spending a lot of money, I wish i had just gone and bought a new BB Turbo.
Matt
