I need power fast!
I need power fast!
Postby quicklvn » Tue Jul 11, 2006 5:44 pm
Ok guys I've just bought a AE101 with 20V silver top and i'm off to the drag strip in a couple of weeks to test it out at the winter drags.
the car has a 2 1/4" exhaust right through and a HKS pod filter, it goes pretty hard but I would like to get a bit more power out of it before I take it down the strip.
Are there any fast (and cheap) ways to get a bit more power to lower the time a bit?
Cheers guys :D
quicklvn
Postby Adydas » Tue Jul 11, 2006 6:01 pm
Ya cant do things cheap just wont work..
Adydas
Postby Jebus » Tue Jul 11, 2006 6:27 pm
Strip it out, get rid of sounds especially subs and shit, spare tyres, rear seats. Run standard wheels all round, but with good rubber on the front. Other than that, run 98 maybe a wee bit of octane booster.
Anything more than that will cost $$$ and is more than likely to be ready 100% in a couple of weeks.
Oh and learn to drive it, back country roads, practice your launch and optimal shift points.
Jebus
Postby quicklvn » Tue Jul 11, 2006 7:05 pm
What about NGK Iridium plugs and 8mm leads etc? it only has crap plugs and 5mm leads atm. Im also gonna give it an oil change and give the injectors a clean out. would this kind of stuff help?
quicklvn
Postby escortman » Tue Jul 11, 2006 7:13 pm
quick question for the winter drags how tuff are they on car checks i have coilovers in my fx but havnt gotten roun dto gettin it a cert yet, will they still let me race?
4x4 toyota blizzard offroader
escortman
Postby quicklvn » Tue Jul 11, 2006 7:16 pm
As far as i know you just need a full licence, a racing helmet and a current WOF & Rego
quicklvn
Postby escortman » Tue Jul 11, 2006 7:21 pm
o ok cuz i got all that shit but i thought they did pre race checks as well to make sure everythign is safe
escortman
Postby Dell'Orto » Tue Jul 11, 2006 9:45 pm
quicklvn wrote:What about NGK Iridium plugs and 8mm leads etc? it only has crap plugs and 5mm leads atm. Im also gonna give it an oil change and give the injectors a clean out. would this kind of stuff help?
Might make an extra 2hp, 5 if the old ones are screwed.
Nitrous is your best bet for extra power cheaply.
Postby Bling » Tue Jul 11, 2006 9:53 pm
imo stripping out an ae101 is not worth the effort for the SLIGHT gains to be had, interior doesnt weight THAT much, you would look pretty hardcore tho if ya did, thats about it :P
best bet is to get the best tyres you can on the front, eagle F1s would be good, and just see how ya go, you're not gunna get 10s so just have fun 8)
Postby Mr Revhead » Tue Jul 11, 2006 11:50 pm
put air box back on with k&n panel filter
fit oil catch can
run 98
learn to drive it
Postby Crampy » Wed Jul 12, 2006 8:02 am
To Escortman.
At the drags the generally have a quick look under the bonnet and check the battery is attached securely and sometimes check the radiator overfill bottle is ok. They check you have a certified helmet and if your brake pedal is firm. They look at your tyres too sometimes.
You'll be sweet as without the cert. They even let me through without a current WOF in my BZ-G once, it had been expried for a month or so :oops: oops.
Crampy
Postby Crampy » Wed Jul 12, 2006 8:06 am
With the winter drags, from memory it's all DYO, so it's all about consistency, not outright power and speed. Just learn how to read the light tree well and get your reaction time down nice and low and run super consistent. That's how I beat a 12 second EVO in my BZ-G a while back.
Crampy
Postby 4000GT » Wed Jul 12, 2006 9:18 am
The black and silver top have really crappy torque. You best chance at going faster is to rip out everything not welded down and to learn how to launch. I would expect you will get a mid 16 maybe even a 17. Pretty slow cars.
Supra MKIV Aerotop (UZA80FTE conversion) STATUS: 3 months to go!
Nitrous is like a hot chick with a STD..... you know you wanna hit it, but you are afraid of the consequences.....
Free online business and reporting tools visit www.e-solver.com
4000GT
Re: I need power fast!
Postby Lanius » Wed Jul 12, 2006 10:32 am
quicklvn wrote:Ok guys I've just bought a AE101 with 20V silver top and i'm off to the drag strip in a couple of weeks to test it out at the winter drags.
Cheers guys :D
Please use the search function. This question has been asked and answered a million times.
Lanius
Postby Jazza » Wed Jul 12, 2006 10:46 am
1 Word...
3sgte :lol:
1996 Curren - On Tardme
Jazza
Postby Leon » Wed Jul 12, 2006 11:19 am
Another word "corners".
Much more challenging ;)
Postby Mr Revhead » Wed Jul 12, 2006 11:28 am
if you cant get a mid 15 theres something wrong
blacktops in ae111s can do high 14s
Postby soopachargen » Wed Jul 12, 2006 1:26 pm
you need naws... two of the big ones
When in doubt, down and out.
soopachargen
Postby Crampy » Wed Jul 12, 2006 1:33 pm
My AE111 BZ-G did 15.7, but I ended up winning cause I was doing it consistently.
I didn't have a cold air feed and didn't strip it out at all though. Take your headlight out and get a good cold air feed and go as nuts as you can be bothered with stripping it out. Then you might be looking at low 15s, high 14s. Bearing in mind you'll have to put all the $hit back in again once your done.
I haven't seen too many mildly worked 20Vs get into the 14s. I had an EE80 Sedan with a silvertop conversion, that was quite quick, but nothing to write home to Mum about.
Crampy
Postby Black » Wed Jul 12, 2006 6:08 pm
throw some custom cams in there. kelford cams know what they are on about
Black
