electrical issues
electrical issues
Postby bluemaumau » Thu Apr 05, 2007 7:28 pm
ok well for the last few months ive been trying to ge the gze going ive been having some troubles.
1. ecu fried itself. -was sweet before it was removed.
2. alternator completely fried. - was also fine.
anyone got any ideas as to what could have happened?
and anything else that could be bung :roll:
:cry:
Postby XSVWGN » Thu Apr 05, 2007 7:41 pm
haha sounds like your haveing more fun then a barrel of monkeys matey.
2008 Kia rio - work car
XSVWGN
Postby bluemaumau » Thu Apr 05, 2007 7:54 pm
XSVWGN wrote:haha sounds like your haveing more fun then a barrel of monkeys matey.
my sig wrote:i need a leprechaun urgently, pm me.
yup :cry:
nothing has gone right.
Postby Bling » Thu Apr 05, 2007 8:50 pm
done any welding on the car?
Postby bluemaumau » Thu Apr 05, 2007 9:01 pm
nope
Postby sergei » Thu Apr 05, 2007 9:50 pm
good grounding? As in engine connected to chassis and battery with a thick cable. If you relocate the battery you will have to connect engine/gearbox with thicker cable to chassis as stock setup relies on the thick battery negative terminal cable and not so thick engine to chassis.
Postby Alex B » Thu Apr 05, 2007 10:27 pm
Yeah im going with poor earthing too. Got a couple of good straps going from engine to chassie i take it?
Postby matt dunn » Thu Apr 05, 2007 11:22 pm
what went wrong with the alternator?
May be able to tell what the car fault is by what was wrong with it.
Postby Mr.Phreak » Thu Apr 05, 2007 11:55 pm
And did the alt and ecu die at the same time?? or one went before the other??
Mr.Phreak
Postby vvega » Fri Apr 06, 2007 9:43 am
dose your alternator require a ex regu;ator...some ze ones do......
i killed a ecu pulling the positive lead off creating a nasty voltage spike...so many ways to $&#$% shit
vvega
Postby vvega » Fri Apr 06, 2007 9:45 am
shizzle = gppd
s.hit = bad
can someon fix the world filter so the words make sence
vvega
Postby bluemaumau » Fri Apr 06, 2007 11:39 am
i suspect they did die at the same time, theres only the factory engine to chassie grounings, tiny cables too. one on each side of engine bay.
alternator.
here the picture of the $&#$% bit, theres 4 of these (diodes) and one is completely $&#$%, the dude said thed have to replace alot of other parts aswell
vvega wrote:dose your alternator require a ex regu;ator...some ze ones do......
how would i find that out, its a ae92 4agze alternator.
Postby matt dunn » Fri Apr 06, 2007 1:26 pm
no only the AW11 GZE is external reg.
Chances are that if you did that to the alternator you have had the battery connected backwards.
Postby bluemaumau » Fri Apr 06, 2007 1:36 pm
weird. ok i cant fix high idle, but damn i know what positive and negative terminals are :lol:
do you think anything else could be buggered? all the ignition crap on the firewall?
Postby RedMist » Fri Apr 06, 2007 2:42 pm
You dont have a kill switch in it do you?
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby bluemaumau » Fri Apr 06, 2007 3:57 pm
unless thats a standard feature in a loom, no
Postby bluemaumau » Thu Apr 12, 2007 9:41 pm
can anyone speculate on wther or not other electrical features could be bung?
how can i test ignitors etc?
Postby Stealer Of Souls » Fri Apr 13, 2007 10:34 am
What fried on the ECU?
I doubt that the ECU would be fried from reverse connection. For the sake of a <1c diode I'm sure the factory would've protected it.
I actually know someone who connected the battery backwards (sorry, but yes a blond girl!!!). And it fried all the fusible links and big fuses, but didn't do any other damage. That was a early ninties RAV...
What did you do when it died? There might be a clue there too. Did you try starting the car and it spontaneous died? Or was it running for a bit then died? Or was it just dead one morning?
'86 AE85.5 Levin
Stealer Of Souls
Postby bluemaumau » Fri Apr 13, 2007 12:17 pm
pulled engine out for 4 months, put back in, alternator drained power and ecu was $&#$%, caused it to idle at 3k
