******4agze sc14 rwd bov?******
Postby corolla gt » Mon May 14, 2007 9:24 pm
hi i have a 4agze motor that i am going to put in my starlet it has a sc14 with it and i am making it fit now...i am just thinking down the long run when i go 2 put the motor in can i have a bov on it? it is a a11 big port 4agze if that helps
i have borught a ssq bov off trademe andnow i have been reading on toyspeed if i can put a bov on it?some say no and others say yes what can i beilive ?
CURRENT:TOYOTA 1993 Hilux surf
OLD:TOYOTA 1995 HIACE SUPERCUSTOM TOYOTA SPINTER GT 1985,TOYOTA COROLLA GT 1986 (SMALLPORT)
corolla gt
Postby slighty_sykotic » Mon May 14, 2007 10:44 pm
If you run the factory setup to intake->throttlebody->s/c->manifold. Then no. You can't.
If you want to get all fancy and change the intake around you can. But why?
slighty_sykotic
Postby Calvin » Mon May 14, 2007 11:20 pm
you dont need a BOV on a supercharger set up. BOV's just prevent back spoil and as the SC runs off the crank and is controlled by the motor it shouldnt be a problem
YOu can fit one but its useless. youll probably lose power because of the releasing presure..
Dont bother.
Calvin
Postby bluemaumau » Tue May 15, 2007 1:18 am
s/c whistle is os much more attractive than a stupid suck off valve. 8) :lol:
Postby escortman » Tue May 15, 2007 7:53 am
i wouldnt bother mine had 1 on it and u could here it leaking so riped it off the buttdyno sed it was faster
4x4 toyota blizzard offroader
escortman
Postby Crampy » Tue May 15, 2007 12:03 pm
As already mentioned, it depends on what intake you plan on running. If you have the throttle down stream from the S/C, then you do need one, they normally called bypass valves on supercharger setups (same thing though). Just use a recirc design one, so it doesn't make a crazy noise the whole time.
If you're still using the GZE manifold and throttle arrangement, then no, don't bother.
Crampy
Postby XSVWGN » Tue May 15, 2007 2:01 pm
as others have said dont use one. I have the sc14 rinning on my wagon with a modified by pass valve. Was thinking about a BOV but its just a wank thing. When you head the SC14 scream you will be smiling from ear to ear...trust me!!! :lol: :lol: :lol:
2008 Kia rio - work car
XSVWGN
Postby Zak » Tue May 15, 2007 9:33 pm
I feel like such a d**k being the only one here with a BOV on mine :oops:
There is a reason for it though, but it's a pain in the ass to listen to :(
Zak
Postby soopachargen » Wed May 16, 2007 9:50 am
zak ur a legend having a bov on ur setup... its a primo setup... the only reason u should feel like a dick is for wanting to turbo it instead of keeping the unique supercharged 20v setup
When in doubt, down and out.
soopachargen
Postby corolla gt » Wed May 16, 2007 6:55 pm
well i have just got my manifold bck and it has been ground down so the sc14 can fit on it(just had to grind one of the lugs that holds the piping on)to make it fit and i have to block off the abv now?so since i dnt have abv will i need a bov?
corolla gt
Postby soopachargen » Wed May 16, 2007 7:31 pm
when i had the setup matt is running it had the abv... i wouldnt get rid of the abv unless ur running and aftermarket computer... the abv was bleeding off boost on my setup so i didnt have to add more fuel to compensate...
soopachargen
Postby XSVWGN » Wed May 16, 2007 8:37 pm
soopachargen wrote:when i had the setup matt is running it had the abv... i wouldnt get rid of the abv unless ur running and aftermarket computer... the abv was bleeding off boost on my setup so i didnt have to add more fuel to compensate...
i still have the ABV on the wagon now and i have a spare one if you want it?
XSVWGN
Postby Zak » Wed May 16, 2007 8:41 pm
soopachargen wrote:zak ur a legend having a bov on ur setup... its a primo setup... the only reason u should feel like a dick is for wanting to turbo it instead of keeping the unique supercharged 20v setup
I'm not sure what the plan is yet, I have a turbo, and flanges to do it, but I love the sound of the superchager and it's awsome for over taking :oops:
I just need to plumb the BOV back in, and make it a bit easier to drive off boost, I might hook up a switch to it or some thing for now.
All though I do less than 20km a week in the thing, so it's not too much of a problem at the moment.
Zak
Postby corolla gt » Wed May 16, 2007 10:27 pm
i have a abv aswell but i have been told to block it off haha i dont no what to do now....it will hit the sc if i keep it on though...i heard that the abv makes you only be able to runn 8 to 10 psi is that true
corolla gt
Postby escortman » Wed May 16, 2007 10:48 pm
u do the abv mod to run more than the 9 psi or wateva
escortman
Postby XSVWGN » Wed May 16, 2007 11:43 pm
corolla gt wrote:i have a abv aswell but i have been told to block it off haha i dont no what to do now....it will hit the sc if i keep it on though...i heard that the abv makes you only be able to runn 8 to 10 psi is that true
Trust me mate...the charger DOES NOT hit the ABV. There is very little room between the charger and the ABV but its all good.
XSVWGN
Postby soopachargen » Thu May 17, 2007 6:12 pm
remember he's rwd matt... so its different.
the abv also bypasses air when the supercharger is off boost to make it nicer to drive off boost
soopachargen
Postby Zak » Thu May 17, 2007 7:56 pm
Any one got any pics of this ABV? Also what would you find a larger one on?
Zak
Postby Rick » Thu May 17, 2007 8:21 pm
Zak wrote:Any one got any pics of this ABV?
This pic isnt the factory one, but looks similar
Zak wrote:Also what would you find a larger one on?
On a 1G-GZE of course. (top right hand side)
Postby Zak » Thu May 17, 2007 8:39 pm
Thanks for the pics rick :D
Is the 1g-gze one much of an upgrade over the 4a one, or would aftermarket be the way to go?
Zak
