1st gen SAFC is rubbish. I was told by st hi-tec that they do weird things like cause random stalling etc. Apexi SAFCII & Neo are the go. Had a SAFCII on my black top with no problems at all & gave a nice power gain, especially at lower rpm where the 20v's need it.Vita wrote:I've read conflicting information on the SAFC units but couldn't find a pros/cons list on them.
MAGN1T wrote: NB sensors
Steve
ROBODISCO_20v wrote:1st gen SAFC is rubbish. I was told by st hi-tec that they do weird things like cause random stalling etc. Apexi SAFCII & Neo are the go. Had a SAFCII on my black top with no problems at all & gave a nice power gain, especially at lower rpm where the 20v's need it.Vita wrote:I've read conflicting information on the SAFC units but couldn't find a pros/cons list on them.
One piece of advice, don't try tune it yourself. Get it dyno tuned by someone who knows what they're doing like st hi-tec.
frost wrote:ROBODISCO_20v wrote:1st gen SAFC is rubbish. I was told by st hi-tec that they do weird things like cause random stalling etc. Apexi SAFCII & Neo are the go. Had a SAFCII on my black top with no problems at all & gave a nice power gain, especially at lower rpm where the 20v's need it.Vita wrote:I've read conflicting information on the SAFC units but couldn't find a pros/cons list on them.
i was also told that there only good on 16v 4age engines but the blacktop is too smart for its own good.
interesting to hear about results with blacktops using piggybacks.
i was told that the blacktop ecu is fuzzy logic and over time would revert the settings done by the safc2 and neo to normal factory settings.
as dyno plots on club4ag showed that after a month or so it went back to factory settings and power.
things i found out the hard way was the igniters in blacktops have internal dwell control/or self dwell control.
anyone elso have input would be good as i got a apexi neo for cheap but reluctant to use it if its just fuzzy.
also DON'T road tune it that's a stupid idea.
Vita wrote:frost wrote:ROBODISCO_20v wrote:1st gen SAFC is rubbish. I was told by st hi-tec that they do weird things like cause random stalling etc. Apexi SAFCII & Neo are the go. Had a SAFCII on my black top with no problems at all & gave a nice power gain, especially at lower rpm where the 20v's need it.Vita wrote:I've read conflicting information on the SAFC units but couldn't find a pros/cons list on them.
With the blacktop been a MAP sensor and the silver been MAF - will that info on the ECU reverting back to orginal settings be an issue with a silvertop?
frost wrote:bugger i was hoping it was not true. thanks Sergei for the good info
+rep to you.
Sergei i just saw you have your mines silver top ecu for sale.
was you assessment described above while running the mines ecu?
sergei wrote:
I can say, yes. I had SAFC on mine and only thing it did is make it worse.
I also noticed by monitoring VF it happily reverted itself to factory after a while, if Oxygen sensor is functioning. Or if you do change certain things over certain threshold it would run in semi-limp mode (VF=0V), which equals too rich and no advance. The oxygen sensor affects the full throttle operation, even if it is open loop mode, in long term. When ECU is reset it will start rapidly learning from O2 sensor what fuel trim it supposed to run, and it set long term fuel trim. Also it constantly adjust long term fuel trim to compensate for sensor calibration. Thus adjusting the spring on AFM (or intercepting the signal) will only affect the transients on long term while base line will stay more or less the same.
