GEN IV 3S-GTE differences
Postby anthonym » Fri May 28, 2004 1:52 pm
TWSTD wrote:They use a coil on plug setup - is this whats refered to as direct ignition? This means that if one were looking for an aftermarket ECU for this engine it would beed to be able to run 4 coils right? So a "link" for example will not do as it can only run 3. This said it can be set up to run a wasted spart setup right - but thats less than desirable from what ive been told.... Does the type of ignition timing sensor (in this casee hall) affect your choice of ECU also? what type of ECU's can run at least 4 coils? Particularly those at the cheaper end of the scale...?
Yes coil on plug = direct fire = DFI. Wasted spark is OK, probably as good as individually firing 4 coils to all intents and purposes. However, I doubt anything less than a MoTeC would be able to interface with the standard crank angle and cam position sensors. A cheap ECU is false economy for this application anyway, IMO.
anthonym
Postby Mr Revhead » Fri May 28, 2004 2:00 pm
what about the link plus?? made for that kinda thing arent they?
Postby TWSTD » Fri May 28, 2004 2:31 pm
link plus can indeed run the 4 coils - but I wouldnt have the first clue about crank angle and cam position sensors.... do these engines have a unique setup do they? im still pretty much int eh dark about aftermarket ecu's and which would be suitable for use with the standard sensors..... suggestions welcome!
Click here!
TWSTD
Postby Lanius » Fri May 28, 2004 2:44 pm
TWSTD - try this link ...
http://www.prostreetonline.com/pso/page ... rticleid=1
Found it looking for info on DIS ignition earlier, helps heaps :)
Lanius
Postby Mr Revhead » Fri May 28, 2004 2:47 pm
have a look here:
http://www.link-electro.co.nz/home.html
i havnt had first hand experience of them but all the horror stories iv heard have turned out to be tunning or installing errors.
i think they can use std sensors but best to check with them on that!
Postby TWSTD » Fri May 28, 2004 4:15 pm
thanx for the links ppl.
Click here!
TWSTD
Postby turbo tezza » Fri May 28, 2004 4:47 pm
A power fc will run the altezza duel vvt-i setup (gen? 3s-ge) geting 1 for my car next week.
Corey
turbo tezza
Postby GT-T » Sun May 30, 2004 10:37 pm
Does anyone know approx. how much hp it will produce from a Gen IV 3SGTE engine (ST215W) under 1.0bar?
1999 Caldina GT-T
2000 Merc A160
1998 Integra Type R
http://toyspeed.blakjak.net/profiles/profile.php?id=581
GT-T
Postby Twolitre » Sun May 30, 2004 11:04 pm
GT-T wrote:Does anyone know approx. how much hp it will produce from a Gen IV 3SGTE engine (ST215W) under 1.0bar?
What intercooler, what turbo and what ecu?
quite a few variables but putting your car on a dyno would give you a certain figure but "approx" 300Hp is a good guess with exhaust mods.
Twolitre
Postby GT-T » Mon May 31, 2004 12:34 am
Thanks!
Also, can amyone tell me which turbo does ST215W used?
CT20B or CT26? Steel turbine or Ceramic?
Whcih one is better? and What are the differences between CT26 and CT20B?
Sorry for all these stupid questions...but I really want to know. :)
Cheers for that
1999 Caldina GT-T
2000 Merc A160
1998 Integra Type R
GT-T
motec m800
Postby Celica RA45 » Mon May 31, 2004 1:23 am
im running a motec m800 on the altezza engine and the magnetic sensors that it has crank and cam shaft work fine can run all the std sensors bar the knock sensors and you can define them easy with the volts in the ref and sync modes
Celica RA45
Postby TWSTD » Mon May 31, 2004 11:36 am
The ST215W uses a ceramic CT20b. These spool pretty quickly but cannot handle as much boost as a steel shaft turbo. I believe some ST205 CT20b's are steel and some ST185 CT26's are steel - the rest are all ceramic. If you are running no more than 1 bar then you wont be in much danger of destroying the ceramic CT20b that came in your wagon :-)
Click here!
TWSTD
Postby Al » Mon May 31, 2004 3:06 pm
Only the WRC spec ST205 ct20b had a steel shaft. ST185 RC's had the steel shaft ct26.
CT20b is better IMO than a ct26...even a steel wheeled ct26, the exhaust side of the ct26 is too poxy and small to make any decent power, only thing ct26 is good for is sub 4000rpm torque.
Al
Postby GT-T » Mon May 31, 2004 3:52 pm
There are a few argument related to CT20B and CT26 Turbo
Very interesting and very confusing as well.
Not sure who is correct.
Have a look...
http://www.automotiveforums.com/vbullet ... p?t=165220
1999 Caldina GT-T
2000 Merc A160
1998 Integra Type R
GT-T
Postby Mr Revhead » Mon May 31, 2004 4:01 pm
with reguard to that link, that guys is correct. sorta. there is no reference to the ct20b in parts books epc or toyota tech books etc etc. but they do exsist! just like gear boxes, to toyota epcs w55 etc etc means nothing!
i was under the impression there is a ct20 (dunno what that fits, maybe surfs?) ct20b and the ct26. iv been told that the ct20b is a hybrid of the ct20 and ct26
Postby Al » Mon May 31, 2004 4:11 pm
yeah ct20 is from the turbo diesel surfs and off the 3tgte engines? correct me if im wrong. total POS turbo, its a wonder there are still 2nd hand ones around.
Al
Postby Mr Revhead » Mon May 31, 2004 4:13 pm
oh the mobile smoke machines? :lol: yeah still some around. i think we've got one down the end shed
Postby Twolitre » Mon May 31, 2004 5:26 pm
Al wrote:Only the WRC spec ST205 ct20b had a steel shaft. ST185 RC's had the steel shaft ct26.
Stock vs stock a CT20b is better than a CT26 but the CT26 has the larger turbine of the two and the CT20b having the larger compressor.
Hyrbid the CT26 with a T04E and you will have a superior turbo to that of the CT20b in regards to horsepower but the CT20b has less lag
Twolitre
Postby fivebob » Mon May 31, 2004 5:48 pm
Twolitre wrote:Hyrbid the CT26 with a T04E and you will have a superior turbo to that of the CT20b in regards to horsepower but the CT20b has less lag
Then why do they only make 288whp when the CT20B has been known to make 319whp see http://www.turboforum.net/dyno/ for details. The closest modified CT26 (Actually a complete recast of the housing to mate it to a GT35R compressor) was 304HP
For a more authoritive answer on the "Does the CT20B exist" lets consult TTE http://www.tte.de/st205.html , they call it a "Toyotas Manufactured CT20 Twin Entry". So Toysport can once again go and sulk in their corner mumbling 503E, 503E, 503E....
Postby Twolitre » Mon May 31, 2004 6:01 pm
Identical modifications? Identical boost pressure?
One member here installed a CT26/T04E onto his ST205 after his CT20b failed and said it was considerably quicker on 15 psi than that of the CT20b on 18psi
No other mods were done before or after installing the new turbo.
Twolitre
