Just done a 4age swap and... (Its finally a runner!!!)
Postby 4AGTE » Fri Jul 23, 2004 5:13 pm
Dident know a temp sensor would make it run to rich to start. Have you no oxy sensor?
4AGTE
Postby skoty » Fri Jul 23, 2004 10:29 pm
4AGTE wrote:Dident know a temp sensor would make it run to rich to start. Have you no oxy sensor?
Well apparantly, read up on fuel injection if ya unsure :wink: The reason being basically on a cold start the temp sensor will tell the ecu to get the injectors to spray more fuel into cylinders in order for it to run, sorta like a choke.
Profile - Cars Owned - AE82 Corolla GT / Corolla Dirt Track Car / N14 Pulsar GTI / S14 Silvia Qs / Nissan Van / Nissan Avenir GT
Current cars - Altezza RS200 and Mitsi Lancer GSR
skoty
Postby TRDWGN » Sat Jul 24, 2004 9:35 am
NZ model = No O2 Sensor,
TRDWGN
Postby Drifter4ag » Sat Jul 24, 2004 10:46 am
it should still run ok with the brown or green plugs unplugged brown = cold start injector and green = water / engine temp sensor it just means you had no cold starter which is prety vital in a cranking situation
Garage |-" '|
Current Rides
Vitz RS :D
Previous,
JZX91 MARK II CHASER
Drifter4ag
Temperature Sensors....
Postby jondee86 » Sat Jul 24, 2004 11:27 am
From memory there are two temperature sensors that are active at startup. One switches the fifth injector on until the water temp rises. The other inputs a signal to the ECU that causes it to richen the A/F at cold temperatures. This is the one you tweak to get more fuel from the stock ECU.
Don't know why either would stop the engine firing though ?
Watch this space >>> <<<
jondee86
