kingcorolla wrote:come across FAST IDLE probs on efi..!
sopachrga wrote:Don't know if it coud cause this; but on the 4AGE's the O2 sensor is not heated (I don't think), so That would also mean that you would be getting some odd signals from the sensor untill the exhaust manifold had warmed the sensor up to operation temp.
So that would mean your air fuel ratio will be up the duff untill your car is a bit warmer.
sopachrga wrote:OK. Thanks Matt, I did not know that.
What symptoms would a bad O2 sensor give?
Users browsing this forum: No registered users and 32 guests
