[4age] oil
Postby Pelo » Sun Sep 26, 2004 5:11 pm
It sounds like the same noises an AE92 4age made when I drove it from rotorua to taupo with a jammed shut thermostat which boiled ALL the water away every 10 minutes. But the temperature gauge worked?
Pelo
Postby jondee86 » Sun Sep 26, 2004 6:58 pm
Good point Pelo....you are quite right... I got my wires crossed :oops:
What I was trying to say before I lost my way, was that the temperature gauge can't be relied on to tell you that you have lost your water !!!! It will still give you a reading when all (or most) of the water is gone. Just as you found.
Even when there is only air in the cooling system it will give some sort of reading. But because air is a poor conductor of heat compared to water, the reading could be quite misleading., and lag a long way behind engine temp.
Cheers....... jondee86
Watch this space >>> <<<
jondee86
