Caldina - plug going nowhere? wtf..
Postby snwtoy » Thu Nov 04, 2004 11:37 am
From that diagram it looks like it's part of the aerial then? If so I really want to know how to plug it in cos my radio reception sux (and yes I have the booster plugged in)!
snwtoy
Postby Inane » Thu Nov 04, 2004 1:38 pm
Who has GPS Navigation installed (or had)
and is your plug plugged in or not?
(just an idea)
Another question, does anyone else have their Radio reception totally die when you turn on the rear demister?
Inane
Postby snwtoy » Thu Nov 04, 2004 4:07 pm
How do I tell if GPS is installed?
Thought the GPS antennae was in a side window? *lost*
snwtoy
Postby Inane » Thu Nov 04, 2004 4:09 pm
I believe the GPS attenae is in the side window, not sure
I meant TV / GPS
Inane
Postby gt-trainer » Thu Nov 04, 2004 8:46 pm
had navigation but not anymore its unplugged.mines pluggrd in and also tiptronic?!@mnow i will have ta turn on my demister to check , pretty sure it doesnt.before i changed my head unit the reception was shit,now with alpine its all good,.
gt-trainer
Postby Inane » Fri Nov 05, 2004 9:33 am
my reception is always pretty good, until I turn on my demisters
Inane
Postby fivebob » Tue Nov 09, 2004 11:14 pm
Resistance is 13.7 ohms so I would guess it's a rear window demister, probably cheaper to get them all made the same :D
Now for the next piece of GTT obscure equipment. Who knows what this is connected to and what it does :wink:
Postby snwtoy » Tue Nov 09, 2004 11:19 pm
Is that behind ur dash? I can't work out what part of the car we're looking at.
And the mystery plug is shown on a diagram which shows aerials - so I'm still gunnin for aerial.
snwtoy
Postby fivebob » Tue Nov 09, 2004 11:23 pm
snwtoy wrote:Is that behind ur dash? I can't work out what part of the car we're looking at.
It's in the right rear of the car.
Resistance isn't right for an aerial, should be a lot higher than 13.7ohms.
Postby blitza » Tue Nov 09, 2004 11:50 pm
I aint got the window thingy pluged in to anything, and also, that cable puller i got, but hrrmmmm, solenoid boot release???
MAD Industries Limited
blitza
Postby fivebob » Thu Nov 11, 2004 12:25 am
blitza wrote:I aint got the window thingy pluged in to anything, and also, that cable puller i got, but hrrmmmm, solenoid boot release???
I have confirmed that the missing plug is connected to the demister, but for what reason I can't guess, maybe a 2 stage heater?
The pulley goes to a valve on the right-hand exhaust outlet pipe, must be controlled by the ECU, wonder what it's used for, noise or power restriction?
Postby Farmer_dave » Thu Nov 11, 2004 10:15 am
Fivebob I asked that question a while back, I now have mine open all the time it sounds alot better at idle too, Havent noticed a power difference however, Quite a complex setup though just to make it quieter when its already pretty quiet :?
My Profile:
Now updated with a new pic
http://toyspeed.blakjak.net/profiles/profile.php?id=201
1997 Caldina GT-T
Farmer_dave
Postby Inane » Thu Nov 11, 2004 12:39 pm
I think its something to do with back pressure when your not boosting???
not sure, I had a exhaust expert dude explain it to me,
apparently it gives you a bit more power down low...
nfi tho
Inane
Postby Digitizar » Thu Nov 11, 2004 11:40 pm
**paste these link into browser it wont show here**
beside the pic (it dont let me link to the page directly) for part num 17047 it says EXHAUST PIPE GAS CONTROL, hope that helps
AE111 Levin Light man a fire and u'll keep him warm for a day, light a man on fire and u'll keep him warm for the rest of his life..
Digitizar
Postby blitza » Thu Nov 11, 2004 11:49 pm
welll there you go then, I have the noisy burbly exhaust fitted, so the outside end goes nowhere for me.
blitza
Postby snwtoy » Fri Nov 12, 2004 7:36 am
Wicked... I'm gonna use that for a remote boot release solenoid. Saves me $80!
snwtoy
Postby fivebob » Fri Nov 12, 2004 9:08 am
Might not work as a solenoid, it's a 3 wire connector so it's probably a stepper motor,i.e. earth ,power,signal.
Why do you need remote boot release anyway?
Postby fivebob » Fri Nov 12, 2004 9:43 am
Inane wrote:I think its something to do with back pressure when your not boosting???
To that statement I raise the BS flag so you can all proudly salute it :twisted:
Sounds to me like your so called expert was just another of those unknown drips under pressure i.e. should be spelled X-Spurt :lol:
AFAIK there's no way a turbo motor (or an NA for that motor) performs better with restrictive backpressure. The only good form of backpressure is that generated by reverse pressure waves, which is timed to arrive at the open exhaust port, just before the valve closes, to push any escaping inlet charge back into the cylinder. See http://www.optimum-power.com/popup.htm for a simulation of the pressure map in a 4-Stroke engine
Next time someone feeds you that line, ask them whether they've read, and understood, the following book. If they say yes, ask to see their PhD, and send them my way cause there's some parts of it which are just too confusing for me to comprehend 8O
Postby blitza » Fri Nov 12, 2004 9:55 am
you got a phd??
blitza
Postby fivebob » Fri Nov 12, 2004 10:14 am
blitza wrote:you got a phd??
Nope, not yet. (University bored me to tears, so I got a job instead) :twisted: which is why I posted this line.
fivebob wrote:and send them my way cause there's some parts of it which are just too confusing for me to comprehend 8O
