Take it to Toyota or a "generic" mechanic?
Postby Mr Revhead » Wed Jan 19, 2005 11:32 pm
at least you know that when you go to a franchised dealer, you are covered if things go wrong... they will usually bend over backwards to sort out any problems.
and if you have an odd model, a dealer has a better chance of having the correct info on its service... iv seen a few f**k ups caused by ppl not knowing the proper service routine...
but thats not to say theres good unfranchised repairers....
Postby levin_it_large » Thu Jan 20, 2005 8:16 am
darkman u could try Mairangi bay motors the place behind the caltex gassie up by windsor park. they good guys, reasonable price and have neva had any issues with them for over 4 years, plus the mechanic wants 2 buy my car so i get stuff on the cheap side :lol:
levin_it_large
Postby darkman0101 » Thu Jan 20, 2005 11:19 am
Hehe, Look man fix my car on the cheap so that one day if I ever do sell it to you I can charge you more for it.
He should be introducng a few intermitent easy to fix hidden gremlins so that you'll be more keen to flick it off.
Cheers man.
darkman0101
Postby Rasker » Mon Jan 24, 2005 8:13 am
Had a major oil leak last August, my usual mechanic called it as being the Head Gasket needing replacement, thought that was a little odd, so took it into Toyota Botany who after 30 minutes of poking around found it to be the Rocker Cover Gaskets, Distributor O rings, and the Oil Sump.
They did a good job took them all day, even called me up when they thought there was another problem with the bearings, even checked out the potential issue for free.
All in all their parts were rather pricey, but the labour worked out the same as my normal mechanics rates.
They did a good job hasn't leaked a drop of oil since so in a classic rating system it would look like this (1-10, 10 being best)
Part Pricing - 5 ($310 for an oil sump........ F&^K!)
Labour Charges - 9.9
Knowledge of a SW20 - 10 (were able to get the aircon compressor off the car easily, others wanted to remove the head gasket to get to it)
Administration side - 7 (tended to be lost without the mechanics)
Likely hood of taking a stickey problem to them again - 8
Apart from the part pricing and the admin side being a bit slow, I'd happily take my car back when another tough to figure out issue comes up.
Rasker
