4agte problems :O help!!
Postby Lloyd » Wed Mar 02, 2005 6:59 pm
Fred wrote:- when just rolling along in nuetral the revs consitantly drop up and down by .5-1 grand
Also sounds like vacuum leak. My Starlet did that when it spat out some of the inlet manifold gasket
Postby 1598cc » Wed Mar 02, 2005 7:01 pm
any diagrams around for the vacuum hosing setup?
1598cc
Postby 1598cc » Thu Mar 03, 2005 9:57 pm
UPDATE:
as someone said earlier, i dont know how to check codes.
its actually puttng out a code 12!!
its actually a code 12:
DISTRIBUTOR/CIRCUIT
--STARTERSIGNAL CIRCUIT
--IGNITER/IGNITER CIRCUIT
--ECU
No "NE" or "G" signal to ECU within 2 seconds after engine has been cranked
How can i check the NE or G signal? whats that??
cheers!!!!
1598cc
Postby 1598cc » Sat Mar 05, 2005 2:16 pm
replaced the ignitor, didnt help at all .
1598cc
Postby vvega » Sat Mar 05, 2005 5:02 pm
sounds like you have a bad wire connector on the loom
basically measin the ecu is getting no feedback at to say it running so it kills the fuel pump
v
vvega
Postby CAMB01 » Sat Mar 05, 2005 9:14 pm
That maybe an old code that hasn't been cleared, disconnect the battery for about 1 min then reconnect and check the ECU code, if its still there then u have a problem, sorry i can't help don't know much about the electronic side of things.
1993 Mitsubishi EVO 1 Racecar
1989 AE91 FX-ZS (Previous)
Custom Works Automotive
http://www.HCCC.org.nz
CAMB01
Postby 1598cc » Mon Mar 07, 2005 9:27 am
getting brendan to come look at it 2nite. should sort the problem :D
1598cc
Postby 1598cc » Wed Mar 16, 2005 8:47 am
Fixed!
The plate underneath the throttle body literally fell off so there was a massive vacuum leak there. All sorted now so can finally get these extra injectors to do there job!
peace!
1598cc
Postby ~SlideWays~ » Wed Mar 16, 2005 11:45 am
1598cc wrote:Fixed!
peace!
I just fixed mine too, turned out to be blown gaskets gallor :roll: (skimmed manifold face, replaces metal gasket between manifold and turbo, replaced gasket between turbo outlet and pipe flange)
Idles good too.
The things u learn by just wadding in with a socket set 8)
~SlideWays~
Postby jury_nz » Wed Mar 16, 2005 11:21 pm
also, another way to check manifolds etc for leaks, get a can of ether and spray it rounds flanges, vacuum hoses etc, you'll be able to hear a change in engine noise if it finds a way into you intake...and remember try not inhale too much of the shit :roll:
Bluetop Bits 4sale
viewtopic.php?t=27554
jury_nz
