Turbo 4K?
Postby pervert » Fri Mar 11, 2005 10:11 pm
HRT wrote:Buy my crappy old Mirage. I'll put a warrent and rego on it if ya like, motor was rebuild about 20 kms ago (not thousand, 20kms) but the car is a POS :)
Haha, I'll pass thanks. Has to be rear or four wheel drive... :lol:
pervert
Postby matt dunn » Fri Mar 11, 2005 10:21 pm
FYI,
The 1GGZE and 1GGTE engine's had rods and pistons that are a direct fit into a 4K, same bore size, same big end bearing size, and same distance from the centre of the crank to the top of the piston, and yes I have done that and they do fit.
Also,
using the 4K twin squish japanese pistons and the NZ 4k head you get a super low compression ratio that is ideal for boost, but still uses old 80's design N/a pistons.
Matt
Postby vvega » Fri Mar 11, 2005 11:03 pm
matt dunn wrote:FYI,
Matt
hehe thats what we did :D
it was a bloddy fast sr coupe i tell ya
used to piss of all the fxgt boys :D
v
vvega
Postby Dell'Orto » Sat Mar 12, 2005 1:11 pm
Also,
Matt
Any idea of what compression both of those options take the motor to?
Postby vvega » Sat Mar 12, 2005 4:03 pm
7.5:1 :D
v
vvega
Postby solberg Fan » Sun Mar 13, 2005 3:15 pm
This may be wrong, but cant you use a 3k crank as it has a shorter stroke for less compression? Thats what i have in my 4k altho it has has high compression with the deck height changed.
But with a normal 4k block, it would work wouldnt it?
Team KB' Racing
in association with CRC
1981 DX corolla
*My KE70*
Before you judge someone, you should walk a mile in their shoes. That way, when you judge them, you're a mile away and you have their shoes.
solberg Fan
Postby RS13 » Sun Mar 13, 2005 4:09 pm
Meh, flag the turbo 4K, a rotary or 4age conversion would cost you around the same kinda money, and give you just as much horsepower, much more reliably.
As I said, my friends' old 4K turbo KP60 was cool, but shat gearboxes/diffs/driveshafts all over the show, and eventually shat itself. That, and the fact that it wasn't much faster at all, and would get owned by pretty much everything else he raced, made the idea seem pretty stupid, all for the fact he couldn't be bothered messing around with mounts etc.
You car is a KE70 right? Just find a AE70 3A-U crossmember/subframe, it bolts in and gives you 4AGE mounts, and larger brakes (?), then a couple of hundred bucks to get it wired up, electric fuel pump, drop in a 4AGE, you'll be away laughing.
My 2c anyway!
RS13
Postby pervert » Sun Mar 13, 2005 4:12 pm
It is not getting a 4AGE...just don't want one...
pervert
Postby matt dunn » Sun Mar 13, 2005 4:24 pm
pervert wrote:It is not getting a 4AGE...just don't want one...
exactly, why would you want to put one of Toyota's most famous, most reliable and most cost efficient engines in your car.
Postby pervert » Sun Mar 13, 2005 4:35 pm
Your sarcasm lacks somewhat...every second KE70 has a 4AGE in it, that makes me yawn...after all, it is MY car...
pervert
Postby vvega » Sun Mar 13, 2005 4:53 pm
2zz conversion :D
7age....
or....
1uz ??
or go the turbo 4k :D
i think the 4k is still the most cost effective engine ive ever run.......
v
vvega
Postby pervert » Sun Mar 13, 2005 5:06 pm
vvega wrote:2zz conversion :D
7age....
or....
1uz ??
v
I have grown to love mine, its just so easy...
pervert
Postby RS13 » Sun Mar 13, 2005 11:51 pm
Personally, I'd have much more respect for an angry n/a 4K than a turbo'd jobby, only because I've had experience with them!
I recall a PC mag a while back, with that baby blue KE25 with a dirty 5K with sidies' and a Lynn Rogers cam, ran a 15.3 or something? Pretty good for an old lump! A mate of ours Gtech'd his GTSt the other day, he ran 15.3 as well, kinda makes you go WTF!!
Honeslty man, if you decided to go 4AGE, I would make the trip down to give you a hand! :D
RS13
Postby nite b » Mon Mar 14, 2005 1:05 am
We did a couple back in the day in KP's. A lot of pissing around, but cheap & real cool, just because its a K motor :D
1- 5K decomp'd(alot), T25, 1 3/4 SU suckthru, 26psi!?
2- 4K std comp, T3(!?),modded 4k carb, blowthru, 12-15psi, 84kw atw.
3- 4K std hi comp,mild cam,IHI turbo,modded 4k carb blowthru, 9psi
Nothing extravagent, but surprisingly reliable :D
Convert Ltd
The conversion specialist
nite b
Postby matt dunn » Mon Mar 14, 2005 11:25 pm
pervert wrote:..............every second KE70 has a 4AGE in it, that makes me yawn...after all, it is MY car...
Dont get me wrong, if you want to do it, do it,
that's why i made some good suggestions earlier.
