4AGZE into AE111
Postby Mr Revhead » Tue Apr 19, 2005 10:13 pm
yup rods and cranks are the same in s/t as 4agze.
i say call HRT and make an offer :wink:
link would be my choice, but microtech and motec will do the job aswell, just i think link will be cheaper. cant remember the place in dunners that does it.... turbo vehicles?? cant remember....
Postby Lloyd » Tue Apr 19, 2005 10:15 pm
The Turbo Shop would be the place you're thinking of
Postby Mr Revhead » Tue Apr 19, 2005 10:18 pm
thats it!!! turbo vehicles is in aucks.
cheers 8)
Postby 10k 20v » Tue Apr 19, 2005 11:27 pm
there' another version of gze rod that has more meat than the silvertop.
10k 20v
Postby Mr Revhead » Tue Apr 19, 2005 11:30 pm
yup the early 4agze or 16v redtop red/black top rod.
chunkier. if thats what you come across then use those, the s/t type will rev a bit free'er, but in a road engine, could you tell?
Postby Gavin » Wed Apr 20, 2005 3:36 am
CrAiG wrote:Thanks for all the replys guys
Also i would probably need some bigger injectors and fuel pump wouldnt i?
Thanks again
The SW20 3SGTE 430's will pop right in and be good to the 300-350 hp area. Don't know if the later ones (440's?) are side feed but if they are they will work as well. 2jz injectors will also fit but are overkill.
You could get an SW20, JZA80 or MA70 pump as well, would be perfect.
ADMIN EDIT: stupidly large image removed
20v Powered AE92 wagon (20v turbo project)
78 280z Black Pearl Edition AutoX'er
Gavin
Postby Gavin » Wed Apr 20, 2005 3:45 am
Mr Revhead wrote:yup the early 4agze or 16v redtop red/black top rod.
But use the ST block!
http://www.club4ag.com/faq%20and%20tech_pages/4A-GE_technical_specifications.htm
Or I would, guess you could not..
Gavin
Postby Mr Revhead » Wed Apr 20, 2005 9:21 am
sorry gavin, i dont get you point...
Postby Gavin » Wed Apr 20, 2005 10:35 am
Well according to those specs the AE111 block is 'non ribbed/lightened.' Does that not matter much?
Gavin
Postby Mr Revhead » Wed Apr 20, 2005 10:48 am
ah ok, not aware of many changes there.... only block probs iv heard about with the b/t has been casued by rods punching holes in them!
http://forums.toyspeed.org.nz/viewtopic.php?t=18953
maybe someone should weigh them if they can?
Postby 10k 20v » Wed Apr 20, 2005 8:00 pm
nah blocks fairly identical, however i have seen one extra bump behind the water pump on the blacktop vs silver. I don't know if they all have or not
10k 20v
Postby CrAiG » Wed Apr 20, 2005 8:05 pm
thanks for all the help everyone
I'v decided against the 4AGZE idea and i think what i will do is what you guys have mentioned. Build my blacktop with AGZE pistons, silvertop rods & crank, new bearings and seals, 3SGTE injectors & pump, cumton manifold with a TD04 turbo, front mounted IC, custom intake plenum for quad throttle and a new computer and tune.
Does this sound right to you all? Safe to run RELIABLY everyday?
thanks again
CrAiG
Postby Mr Revhead » Wed Apr 20, 2005 8:26 pm
sounds good to me, good luck :D
Users browsing this forum: No registered users and 22 guests
