VVT Light ---> MORE HELP PLZ
Postby BZR4AGE » Wed Aug 03, 2005 9:20 pm
yep~ thts my plan.
will e-mail you when i saved enough for the rebuild. Cheers :D
BZR4AGE
Postby Xavier » Wed Aug 03, 2005 9:30 pm
dude, stop making me drool on those parts, that is wat i would like to do in future when i got the $$$...
i need an IT job, just gradudate from AUT... :D
anyone need an IT staff... full time... :D
Cheers...
My Profile
1999 Altezza AS200 Z
1995 Trueno BZG (Previous)
1992 MR2 GTS (Previous)
Xavier
Postby phatman3801 » Wed Aug 03, 2005 10:22 pm
what sort of ecu you gunna run with all this?
current project/ride: BZG levin
phatman3801
Postby BZR4AGE » Wed Aug 03, 2005 10:30 pm
I am planning to get a Haltec or motec depending where in North island they can tune it best. But in the mean time, i will be running it with a Blitz ECU probably with a piggy back like apexi SAFC.
Toda japan already inform me that the camshaft will idle fine if it is installed in normal position (what ever tht meant). But ofcause i understand to achieve best result i will need to get a whole new ECU.
Was thinking about the Greddy E-management, but some people in Japan told me they are hard to tune and not as accurate.
BZR4AGE
Postby AceSniper » Wed Aug 03, 2005 11:31 pm
isnt that abit high for our gas 11.8 ...
kelford cams is ment to be working on getting stanless valves for 20v might pay to talk to them... stock replacements are damn expensive.
does this include a ecu? if not what are you using?
and any idea of the price of the intake pully by its self?
AceSniper
Postby BZR4AGE » Wed Aug 03, 2005 11:50 pm
after installing the parts i will probably use 98 for daily driving, when i do dyno and track sprints, i probably use octane boost in conjunction with 98 to raise the level. Afterall. I am only building a cross between street / track car.
As for ECU, see the above post. Motec or Haltec.
Yep. lets hope they are out when i finish saving money.
There is a TODA supplier in NZ, but i didn't get these from them. I got it direct from my friend direct from TODA Japan.
BZR4AGE
Postby AceSniper » Thu Aug 04, 2005 12:02 am
im hopping to get away with safc with larger cams than yours but I dono along with AFM ecu I can hope it will work :P
AceSniper
Postby vvtlevin » Sun Aug 07, 2005 5:25 pm
what is the vvt light for?
vvtlevin
Postby Xavier » Sun Aug 07, 2005 10:01 pm
vvtlevin wrote:what is the vvt light for?
shine a ray of hope on u when u r reaching 5000rpm.... 8)
Cheers...
My Profile
Xavier
Postby Mr Revhead » Mon Aug 08, 2005 9:43 am
i fitted one on sat, temporary fitting to test a new ecu as theres no need for one otherwise.
found my ecu switchs on vvt ast anything over 1/4 throttle at anything over half warm guage temp.
its sensed soley on TPS. as i can be parked and stab the throttle and the light comes on imediatly before the revs even change.
i think preface lift ae101s switch at 4000 odd though.
Postby vvtlevin » Mon Aug 08, 2005 12:31 pm
so it just tells u wen vvt kicks in?
vvtlevin
Postby Silent Knight » Mon Aug 08, 2005 12:36 pm
vvtlevin wrote:so it just tells u wen vvt kicks in?
Yes, so in reality there's no real point in having one cept for teh Rice Fact0r!!
Silent Knight
Postby Mr Revhead » Mon Aug 08, 2005 12:42 pm
yes, pure rice factor
as i said the only reason i fitted one was to test different ECUs, and i fitted plugs so i can remove it in about 30secs.... also just taped the bulb to the gear lever boot! lol so rangi, but it works :lol:
Postby sergei » Mon Aug 08, 2005 8:46 pm
heh, I've actually installed it exactly where the SC light on GTZ, its too a green LED, the only difference that I have no writing under it (could of made vinil sticker, but that too lame)...
Postby Bling » Mon Aug 08, 2005 9:12 pm
can always think of it as a petrol saver :P when it comes on lift ya foot a bit :P
although, this only applies if u want to save petrol, and doesn't help much else :P
Postby Mr Revhead » Mon Aug 08, 2005 9:31 pm
its f**king near impossible to drive with out activating vvt 8O
Postby vvtlevin » Wed Aug 10, 2005 12:18 pm
wheres the place you plug it in to?
vvtlevin
Postby Mr Revhead » Wed Aug 10, 2005 12:23 pm
i have mine plugged into the vvt wire from the ecu, and the power wire to the cig lighter.
but really, you dont need one
Postby vvtlevin » Wed Aug 10, 2005 12:29 pm
how do u know witch 1 is the vvt wire.yeah i know but i wanna get it set up so i can do it easy in future
vvtlevin
Postby Mr Revhead » Wed Aug 10, 2005 12:34 pm
http://www.turbocorolla.com/tech/default.htm
if you cant sort it from there, please get some one else to do it for you.
it really is easy once you look at it and think about it.
but again, why do you want it?
