apply the throttle, engine stalls.... :-S
Re: apply the throttle, engine stalls.... :-S
Postby matt dunn » Mon Aug 01, 2005 11:51 pm
Back to the first post,
skoty wrote: the only way to rev the engine is to continuosly tap the throttle a million times.?
To me that means that it is running on what is basically the accelerator pump.
This means to me that the TPS is sensing and the ECU is clever enough to provice acceleration enrichment,
and also that the car is suffering from a lack of petrol into the cylinders.
Fuel filters give more warning than that, ( usually ) so I would like to place my bet on fuel pump fault.
Matt
Postby skoty » Thu Aug 04, 2005 10:14 pm
THE VERDICT:
Injectors - I checked using an LED to see whether they were all being triggered in which they were. The injectors themselves could not be faulty as the engine was able to idle independently.
Fuel Pump - This was the problem, not the relay as I heard the pump switching on when ever the motor was turned over. I was unable to source a fuel press gauge however i was able to temporairily connect another fuel pump (from a 4age celica gt which wont fit the original tank) in which I submerged in a container of petrol and connected the cars inlet and return lines. This test proved successful therfore I'm on the hunt for a compatible internal pump. The ae82 fxgt uses the same tank/pump as the ae82 corolla liftback gt?
Thanks for the help guys,
skoty.
Profile - Cars Owned - AE82 Corolla GT / Corolla Dirt Track Car / N14 Pulsar GTI / S14 Silvia Qs / Nissan Van / Nissan Avenir GT
Current cars - Altezza RS200 and Mitsi Lancer GSR
skoty
Postby matt dunn » Thu Aug 04, 2005 11:44 pm
matt dunn wrote: I would like to place my bet on fuel pump fault.
Matt
LOL,
What do I win?
Postby RedMist » Fri Aug 05, 2005 8:00 am
Nothing Matt, you were the fourth person in this thread to state it was the pump. :D
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby sergei » Fri Aug 05, 2005 9:21 am
Hey lets split prize in 4? How about that Idea?
Postby skoty » Sun Aug 07, 2005 7:06 pm
Found a compatible pump, fitted it, car runs like a dream :)
skoty
Users browsing this forum: Google [Bot] and 34 guests
