diff uprade for ae86
Postby Low_Aa63 » Thu Oct 13, 2005 4:39 pm
yeah we owned it! this always happens!
ok ok so youre swappind an lsd head from IRS to Live??
It cant work coz the lsd head is bigger in the irs as the axles move and they dont in the live as its fixed! thats gonna be a lot of $&#$% around!
The list so far
Te71, Ae82, Ke70x2, Mx73x2, Ga61, Gx61, Ra63, Aa63, Ae70, Ae85, Ke25, Ke30, Ke36, Gz10x2, Hb11, Ta40, Ma45......
geishaboy wrote:I want a number plate with "geisha" on it
But I should probably get a car first
Low_Aa63
Postby crnkin » Thu Oct 13, 2005 4:47 pm
jeepers boys just get k series lockers and be done with it
deaf_homo "currrently yes"
crnkin
Postby Low_Aa63 » Thu Oct 13, 2005 4:47 pm
Hahahahahaha and run what a 2k??
The list so far
Low_Aa63
Postby fangsport » Thu Oct 13, 2005 6:10 pm
if you don't want to go too heavy, get a diff from a nissan navara or vannette. 190mm crown wheel, 30mm axles,good spread of ratios and some of them are LSD. also have the the same stud pattern on the vans.
fangsport
Postby JustinSpiderholden » Thu Oct 13, 2005 6:17 pm
um the diff i have been offerd is out of a early 1980ty supra celica he model with the 5m i think it is i dont want a shimmed up hilux as they are not goin to handel the jandel once i start dishing out the abuse also i want a good mechanical lsd as the car is goin to be used both on the rd and track what would you guyz recommend
JustinSpiderholden
Postby AE85coupe » Thu Oct 13, 2005 7:18 pm
a shimmed hilux will handle the jandle just as good as a celica supra diff
the issue with the celica supra is it is probably IRS which no good to you
hilux diffs are what the garage dori ae86 drifter guys use
if your running NA just get a trd lsd for the ae86 diff
AE85 Trueno *For sale*
Details of car here
AE85coupe
Postby JamesM » Thu Oct 13, 2005 11:35 pm
hilux diff wont handle the jandel?? oh....
Team Megasquirt
1984 AE86
180kW, 600Nm@wheels @ 16.5psi
JamesM
Postby Low_Aa63 » Fri Oct 14, 2005 12:15 am
Dude a hilux diff will handle any jandle!
Early celice diff will most likley be irs which is expensive to put into an ae86 as a new subframe will have to be constructed and there is also a good chance that you may get a t series irs diff and then youd be back to sqaure -1 as the sub frame would still be required!
and theres an even smaller chance of getting the ma45 celica diff which is just an old school version of the 86 diff being live rear axle!!
even then youve got to worry about ratio's!!
Best bet is hilux rear (possibly off some description of smaller van which will maitain 4 stud hub) with brakes from an old school toyota (disk ofcourse) with external hand brake, and most of the time they will be either 4.1 or 4.3 ratio 4.3 being the better for power applications but 4.1 being a nice overall diff!
Any questions??
The list so far
Low_Aa63
Postby beeker » Fri Oct 14, 2005 6:40 am
Low_Aa63 wrote:Dude a hilux diff will handle any jandle!
Any questions??
Excuse my ignorance,
When you do a hilux Diff into an AE86, you change the diff and the entire axle ? You also mention a hilux diff from a van being more suited. Be intertested to hear more detail here. Is there any write ups ?
94 DC2 Integra Race Car
02 M3 Race Car build
06 RS4 Avant
beeker
Postby fangsport » Fri Oct 14, 2005 7:52 am
the entire live axle from a Hilux is used.
there are many written articles on this conversion. possibly a bit of overkill for N/A use.
fangsport
Postby Drifter4ag » Fri Oct 14, 2005 8:34 am
i wouldnt call it over kill by any means for an na engine . You can beat them all day with no worries at all .. .
wanna win an endurance race? endurance is the key word here ...
the weight increase is marginal ...
switching to turbo hilux and w55 box the weight of my car has only increased by about 30-40kg .. ... and the more weight in the back im guessing the balance is now about 50.50
Garage |-" '|
Current Rides
Vitz RS :D
Previous,
JZX91 MARK II CHASER
Drifter4ag
Postby spencer » Fri Oct 14, 2005 1:49 pm
Drifter4ag wrote:i wouldnt call it over kill by any means for an na engine . You can beat them all day with no worries at all .. .
exactly! I've had t-series break axles with n/a abuse. old school hilux and hiace vans have a short rear if you can spy one. We have a few but they all vary slightly in width its wierd, the shortest being from an old 70's hiace with round lights. And good luck who said to find an old school g series 4 stud van :roll: just restud a short one if you find it
spencer
Postby wde_bdy » Fri Oct 14, 2005 3:16 pm
Low_Aa63 wrote:the only thing similar between f series irs and independant is the crown and pinion wheel size! the spider casing/lsd clutches/whatever you put in there is not the same and will not fit! Irs being the bigger one ofcourse!
Obviously your vast knowledge needs to be shared with all the people who have put an LSD from the MA61 IRS into an F code live axle housing. Or the people who have put aftermarket Tru Trak diffs into both IRS and live axle F code housings simply with different bearings.
Someone better tell them to stop driving their cars because they are really imagining the diff head they thought they had sucessfully fitted. :roll:
wde_bdy
Postby JustinSpiderholden » Fri Oct 14, 2005 4:53 pm
i do not want a clutch type lsd i want a mechanical one can you purcahse a trd lsd for the hilux diff i state i do not want a shimmed up clutch lsd i want to get a diff that i can buy a good aftermarket lsd for cost is not the worry do things once do it right a nice 2 way mechanical lsd is goin to be way better than a shimmed up hilux lsd agree
JustinSpiderholden
Postby wde_bdy » Fri Oct 14, 2005 4:59 pm
Do a search over on http://www.toymods.org.au for Tru Trak.
There is a lot of information there and it may suit what you want.
Callum
wde_bdy
