Turboing silvertop
Re: Turboing silvertop
Postby Santa'sBoostinSleigh » Thu Dec 08, 2005 2:36 pm
trueno_20v wrote:600x300 fmic
why do people insist on using stupidly large intercoolers!
your motors a 1.6L FFS!
Santa's Mega Sale
Santa's TardMe Listings
GTFX: viewtopic.php?t=67655
Postby barryogen » Thu Dec 08, 2005 3:20 pm
why not?(serious question).
barryogen
2ZZ Guru in training
Postby Santa'sBoostinSleigh » Thu Dec 08, 2005 3:36 pm
basically: bigger intercooler = more area to fill with compressed air = more lag
another reason why you dont use 3" pipe for I/C applications (unless you have a seriously big motor/turbo(s) combination)
considering even a 450x300x76 is on the large size for my caldina (2L)
Santa's Mega Sale
Postby barryogen » Thu Dec 08, 2005 3:38 pm
I figured that lag would come into it, yay, I'm learning. so if lags not an issue(boost at 2000RPM) then a bigger one would just cool it better and take the lag out a bit?
barryogen
Postby Santa'sBoostinSleigh » Thu Dec 08, 2005 3:48 pm
nope, cuase the air still has to fill the whole IC and then get pack up to boost pressure, ie get from atmospheric pressure (0psi on boost guage) to positive pressure, remembering that the motor is constantly sucking air
a bigger IC means the compressor (turbo) has to work harder (longer) to get the same pressure in the system.
by running large diameter and/or long length pipework, this also increases the area that the turbo has to fill with air (ie more area to fill = more lag as the turbo cant keep up)
bends can also increase lag - this is due to air velocities etc
every time the BOV opens, the pressure inside the IC + pipework is released and goes back to 0psi on a boost guage
Santa's Mega Sale
Postby rollas22 » Thu Dec 08, 2005 3:49 pm
Turboing your 20v..... DONT BOTHER TURBOING ON STOCK ECU OR INTERNALS!!!!
Rebuild using forged internals (pistons & rods)
custom intake plenium
bov
intercooler (front mount)
custom manifold
turbo (tdo4-5)
Custom sump for oil return
make a t joint off the oil sender for oil feed
Link ecu or different (tuned)
It will work on the standard injectors, mine was producing around 14-18psi on the standard injectors, was tunned to max out at 7000rpm.
Just do it right the 1st time!!! :wink:
Theres bound to be more stuff you can do.....
KE-Corolla's for life!!!
rollas22
Postby suberimakuri » Sat Dec 10, 2005 8:23 am
dyno plot?
suberimakuri
Postby flygt4 » Sun Dec 11, 2005 11:08 am
evo intercoolers are freely available and more than adequate for a 4agte setup.
flygt4
Postby IH8TEC » Sun Dec 11, 2005 12:01 pm
crnkin wrote:
matt recomendign low comp :O what is the world comming too!
run 8.9:1 pistons, with a good af ratio, like just under 12 all the way, and youll be mint, Search club 4ag too, theyre real good, theres a guy running 650+ hp in a 4age with 8.7:1 comp ratio, only prob is the bores keep splitting...... bugger
i think you'll find it was 492wrhp @25psi, and his best power band was between 6500 and 11000 rpm, but his block split from top to bottom in number 1cyl, and has run 30psi,
he is HOPING to break 600hp one day, but that will likely be with sleeved block. unless we aren't talking about the same one, your full of shite :roll:
