All_Fours wrote:the only thing you can see if you remove the oil filter is the oil cooler
lol,
filler not filter, as in the cap that screws ino the tappet cover ........
Adydas wrote:Well i think i have it solved. Thank you toyota for the joy that is TE1 and E1.
12
RPM SIGNAL-NO SIGNAL TO ECU FROM DISTRIBUTOR ("Ne" OR "G") AFTER ENGINE HAS BEEN CRANKED
--DISTRIBUTOR/CIRCUIT
--STARTERSIGNAL CIRCUIT
--IGNITER/IGNITER CIRCUIT
--ECU
