ST185 possible Cam Belt Snap or other problem ???
Postby matt dunn » Wed Dec 28, 2005 1:19 am
All_Fours wrote:the only thing you can see if you remove the oil filter is the oil cooler :P
lol,
filler not filter, as in the cap that screws ino the tappet cover ........
Postby sergei » Wed Dec 28, 2005 1:20 am
he was talking about fiLLer (as in CAP) not fiLTer...
Postby sergei » Wed Dec 28, 2005 1:21 am
bloody hell, I'm typing too slow or what! it is second time!!!
Postby Malcolm » Wed Dec 28, 2005 1:28 am
oops, I thought it sounded a bit dumb for something coming from M.D's mouth/fingers.
I'm pretty sure there's a little thing that stops you from being able to see the cam through the oil filler, but you might just see it on the right angle
Postby Adydas » Wed Dec 28, 2005 11:41 am
Well i think i have it solved. Thank you toyota for the joy that is TE1 and E1.
12
RPM SIGNAL-NO SIGNAL TO ECU FROM DISTRIBUTOR ("Ne" OR "G") AFTER ENGINE HAS BEEN CRANKED
--DISTRIBUTOR/CIRCUIT
--STARTERSIGNAL CIRCUIT
--IGNITER/IGNITER CIRCUIT
--ECU
And ( i know what this ones about tho. )
34
TURBOCHARGER PRESSURE--ABNORMAL TURBOCHARGER PRESSURE
--TURBO CHARGER
--AIRFLOW METER/MANIFOLD/TURBOCHARGER PRESSURE SENSOR
--INTERCOOLER SYSTEM
--ECU
Adydas
Postby Ako » Wed Dec 28, 2005 12:24 pm
Might that just be telling you that its expecting to see an rpm / airflow signal, but getting none?
Honestly.. If you think its a cambelt which has gone, why don't you just spend a bit of time to check that out first? Sounds like from this there has been a lot of guesswork but nothings actually been checked? Even just prying back the wee plastic cover will tell you if its snapped or not.
Ako
Postby matt dunn » Wed Dec 28, 2005 12:53 pm
Adydas wrote:Well i think i have it solved. Thank you toyota for the joy that is TE1 and E1.
12
--ECU
You get that code if you break a cambelt,
as the ECU gets a start feed from the key and does not see the dist turning.
You also get it a lot of times for other reasons when the cambelt is OK.
like a faulty dist sensor, or a wiring fault.
You still need to check visually.
Matt
Postby Adydas » Wed Dec 28, 2005 2:03 pm
Poop0r, Cam belts gone!! 10 points to the Towy, and anyone here that said its gone.
Adydas
Postby Fraud » Wed Dec 28, 2005 3:00 pm
Did it snap, or slip a tooth or what?
Fraud
Postby Adydas » Wed Dec 28, 2005 3:11 pm
Snap, * Twang *..
well the noise i heard sounded nothing like it.. But sure enuf there is no belt visible on the cams now..
Adydas
Postby Fraud » Wed Dec 28, 2005 3:36 pm
Ah that sucks.
Fingers crossed no internal damage, if it cut out straight away it should be ok....
Fraud
Postby WeNdY^cLeAr » Wed Dec 28, 2005 3:55 pm
I belive the trusty 3s is Non interference anyway so it should be ok.. i think theres like a 3% chance it could do damage.
I just took the cam cover off.. things Look ok..so fingeres crossed.
WeNdY^cLeAr
Postby vvega » Wed Dec 28, 2005 6:08 pm
lol it will be fine :D
its not hard to do one in place ethier cliffy
and i think the retail on them is about 40 bucks.....genuine
might pay to do water pump and while your in there
there about 80 bucks retail i think.....genuine
probably take you 2-3 hours to do :D
v
vvega
Users browsing this forum: Bing [Bot], Google [Bot] and 7 guests
