blowing up a p.o.s 4af
Postby YeMs » Wed Mar 22, 2006 11:27 pm
touge rolla wrote:or attack it with sledge hammer whilst running
feck that.. wen doin engine blows i like to have at least 5-10 metres of string controlling the throttle, and something solid close by that i can dive behind. doing motor blows may seem like harmless fun, but u gotta think a little out of the square.. wen u gotta motor spining at 6-8000 rpm (or if its 'tecn' could b any were from 10-100000 rpm, who really knows at the intense acceleration all ur really concentrating on is were to land on the moon), any thing that comes flying off is gunna b flying at a feck load of speed, and generally gunna b rather solid. wont b stopping to say hi with a smile on its way past.
Your local Hybrid Elite tech
YeMs
Postby KwS » Wed Mar 22, 2006 11:41 pm
we had a mazda thing ages ago we did this to...
make sure you have a fire extinguisher at hand. we didnt, and ended up with the fire brigade coming to help us.
Seems the oil in the sump got so hot it caught fire. kept running while burning though, lol.
KwS
Postby Si » Thu Mar 23, 2006 12:20 am
dont do it in a early model honda CRX either, the bonnet will melt :)
Current: , '96 SubaruImpreza
Si
Postby matt dunn » Thu Mar 23, 2006 12:26 am
Ever seen it done with a rotary?
Seen it tried once, just couldn't keep the fuel up to it.
Will be boring to wantch unless you can get it to either run a bearing first before you start,
or as siad before,
advance the timing so it is detronating.
Matt
Postby bluemaumau » Thu Mar 23, 2006 12:29 am
since you want the car make sure you remove the bonnet, so when you put the new engine in it, there isnt a piston or flywheel stencil in your bonnet 8)
Postby Dragger_Dan » Thu Mar 23, 2006 3:30 am
bluemaumau wrote:since you want the car make sure you remove the bonnet, so when you put the new engine in it, there isnt a piston or flywheel stencil in your bonnet 8)
Sure, if you want the flywheel stencilled in your forehead insted of the bonnet
Dragger_Dan
Postby mr pad » Thu Mar 23, 2006 10:33 am
strx7 wrote:GX60 cressida with 1GEU, sat on 8000rpm for 15
$&#$%, i knew I was too soft on my waimakceda. Dont they have a rev cut?
mr pad
Postby clubk » Thu Mar 23, 2006 2:19 pm
fill the motor up with half rocks (gravel) and half oil :D
clubk
Postby Dell'Orto » Thu Mar 23, 2006 3:48 pm
Empty some grinding paste into the oil filler 8)
Postby RomanV » Thu Mar 23, 2006 3:54 pm
Get it running to some obscene RPM, then blast water down the intake.
Hydraulic lock at 7000rpm should be rather spectacular. :lol:
Postby Ako » Thu Mar 23, 2006 4:02 pm
Remember - for it to br truly successful, it has to go "bang" somehow, not just slow down and die...
As many said, plenty of advance, juuuust enough fuel for it to run, HALF empty the oil (more chance of stuff breaking, without it just seizing up)... And stand well clear. You don't want to be near if something lets go explosively - hot oil + metal shards don't agree well with skin and stuff :lol:
Ako
Postby RomanV » Thu Mar 23, 2006 4:05 pm
Bollocks, Chicks dig scars. 8)
It shows that you're hardcore, especially when you drive to the A&E in the car you were trying to blow up, on three cylinders, because the fourth conrod is embedded in your skull. 8)
Postby sry_not4sale » Thu Mar 23, 2006 5:05 pm
AVGAS 8)
1983 Mazda Cosmo 12at
sry_not4sale
Postby Dragger_Dan » Thu Mar 23, 2006 5:17 pm
sry_not4sale wrote:AVGAS 8)
Dunno, it would probably hold on that. I'm still all for trying nitro mix for radio control cars. That would probably cause a bit of damage.
Dragger_Dan
Postby ollieboy » Thu Mar 23, 2006 5:23 pm
DO IT!!!!
ollieboy
Postby ollieboy » Thu Mar 23, 2006 5:25 pm
then post pictures of your forehead:D
ollieboy
Postby bluemaumau » Thu Mar 23, 2006 6:17 pm
you should start a poll on
- how to blow it up (gravel, xsv rpm,etc)
and another on
- how it will die (rod, heat, etc)
god i wana see this happen :D
Postby bluemaumau » Sat Mar 25, 2006 7:41 pm
start a poll dammit :P
Postby sigma » Sat Mar 25, 2006 9:03 pm
We put some nitro in a nearly empty gas tank in our rb30 berlina. Car didnt run very well for a bit, nothing spectacular.
1985 MR2 AW11 20v
sigma
Postby touge rolla » Sun Mar 26, 2006 12:32 am
i started by removing the headers, started it up started to floor it, shot flames made lots of noise, ran out of petrol :( attacked it with hammer, broke a power bar and two sockets trying to get it out, dismantled it slightly then attacked with hammer, hurt my self, attacked it with hammer. sorry to disappoint you all but i was skint for gas :cry:
touge rolla
