Wheel has a terrible habit of dropping off
Postby wde_bdy » Sun Apr 23, 2006 3:57 pm
What model car is it?
Measure diagonally across the studs from inside of one to outside of the other and let me know what this is. If its a RWD Starlet someone may have swapped the hubs/rear axles to KE20 stuff. If this is the case the cortina wheels will go on but are not safe to use as tightening up the nuts will bend the studs in. They are 1.5mm to 2mm further out on the KE20 than the cortina
Callum
wde_bdy
Postby ollieboy » Sun Apr 23, 2006 9:31 pm
As I mentioned before they are Hilux studs
ollieboy
Postby wde_bdy » Sun Apr 23, 2006 10:28 pm
That doesn't actually answer the question, hilux studs are the same as factory ones just around 8mm or 12mm longer ( can't remember exact measurement).
Callum
wde_bdy
Postby ollieboy » Mon Apr 24, 2006 12:16 am
I went out and looked at the wheels they say 114.3 x 4 I am assuming this is the stud pattern? So they must be different cortina models we are talking about
ollieboy
Postby ollieboy » Mon Apr 24, 2006 10:36 pm
Found a pic on the net of my car from a while ago, does this look like it has cut springs?:Image
I am just trying to work out how long the car has had the cut springs and if it is safe with them. If its had them all along then I guess they are safe.
ollieboy
Postby D-T » Mon Apr 24, 2006 10:40 pm
Shell Ashburton! heheh
Who did you get that car off? if ya don't mind my asking :)
94 Curren - 15.84 @ 90.9Mph
1977 MS85 Toyota Crown, Mustard Yellow, and Just as Fast!
D-T
Postby ollieboy » Mon Apr 24, 2006 10:42 pm
A guy in Invercargill. Apparently its quite a well known car. being speaking to a few people and they know it.
ollieboy
Postby Loudtoy » Tue Apr 25, 2006 9:20 am
ollieboy wrote:I looked around about 6 starlets but all the springs were gone :( would any other vehicles use similar springs.
I did however pick up some nice shiny wheels, they are off an old cortina so rwd offset and I kept the nuts so I can use the correct ones. I found an old rally tyre lying round the backyard at home and I was all happy but then I discovered the other rally tyre has been misplace/stolen. I'm real gutted now because the tyre I have has heaps of grip on.
ommon problem with springs being gone on parts cars, seems so many people cut the springs on starlets that original springs are in high demand, you could always go see someone who sells springs locally for you. King spring still list a set of lowered springs for kp6x starlets at no more than new lowered springs cost for any other car, also if you are planning on keeping the car for quite some time and are only going to be doing cicuit work with it then these are probably a good option.
PS What size is that rally tire and do you by chance want to sell it, i ave 7 14" and 3 13" and it's pissing me off that
a) i don't have two complete sets of 14" tires
b) i don't have one complete set of 13" tires
TS Member sine 2001
Prado To tow stuff with
Rodeo to do work stuff in
Loudtoy
Postby ollieboy » Tue Apr 25, 2006 12:33 pm
Loudtoy wrote:ommon problem with springs being gone on parts cars, seems so many people cut the springs on starlets that original springs are in high demand, you could always go see someone who sells springs locally for you. King spring still list a set of lowered springs for kp6x starlets at no more than new lowered springs cost for any other car, also if you are planning on keeping the car for quite some time and are only going to be doing cicuit work with it then these are probably a good option.
They are 13" I will see if I can find the other tyre but If I can't I will consider selling. Also note its an unknown brand of tyre so it might not be any good.
ollieboy
Postby Loudtoy » Tue Apr 25, 2006 10:12 pm
ollieboy wrote:They are 13" I will see if I can find the other tyre but If I can't I will consider selling. Also note its an unknown brand of tyre so it might not be any good.
Fair enough let us know then.
Oh and if your springs were that loose and they were definately cut (that should be easy enough to see) i would recomend taking your rear shocks out and checking them as well, quite often having springs that short for any length of time will stuff the shocks which is another reason not to do dumb shit like that. Sucks to get cars in that state specially race cars. :(
TS Member sine 2001
Loudtoy
Postby ollieboy » Tue Apr 25, 2006 11:49 pm
Loudtoy wrote: i would recomend taking your rear shocks out and checking them as well
Cheers I will do.
ollieboy
Postby ollieboy » Wed Apr 26, 2006 12:39 am
Where would sell these king springs? And how much would I expect to pay?
The reason I ask is I am along way from civilisation and I'm heading out to town in the ute tomorrow true hicks style so I would like to know where I could pick them up. :D
Ollie
ollieboy
Postby ollieboy » Wed Apr 26, 2006 10:10 pm
Supercheap quoted 140 a spring for king springs lows and superlows.
Repco quoted 580 or something for all four and they are cobra springs I believe.
Is this a good price?
ollieboy
Postby Loudtoy » Wed Apr 26, 2006 10:26 pm
ollieboy wrote:Supercheap quoted 140 a spring for king springs lows and superlows.
Thats about right, if you know anyone with a discount card get them to pick a set up for you, you will save lots. Stay away from superlows as you will run out of travle using them especially if you are planning on doing any gravel work and for some reason the thought that super lows aren't captive at full droop (ie when you jack your car up) keeps going round in my head as well. Have heard mixed things about cobra's and mixed to bad things about super low kings but not may people have problems with low kings
TS Member sine 2001
Loudtoy
Postby Loudtoy » Wed Apr 26, 2006 10:30 pm
oops double post
TS Member sine 2001
Loudtoy
Postby ollieboy » Wed Apr 26, 2006 10:31 pm
Loudtoy wrote:stay away from superlows as you will run out of travel specially if you are looking at any gravel work.
Yeah I thought as much, its already boganified enough. :lol:
ollieboy
Postby ollieboy » Wed May 03, 2006 1:25 am
I'm just letting everyone know that wde-bdy was right about Cortina pcd, the reason the wheels I had fitted the cortina was either because the hubs had been modified or they bent the studs outwards, I looked at my friends Cortina you see and I measured it.
ollieboy
