Manual Conversion
Postby PopCorn » Wed Jun 14, 2006 8:33 pm
ok so far i've got this
the parts list for manual conversion:
-modify loom
-shifter
-linkages.
-pivot stud
-thrust bearing
-copper pipe
-fly wheel with bolts
-clutch
-gearbox
-master and slave cylinders and lines
-pedal box
-brake pedal
-gear box top mount
-gear stick with cables
-interior trim
-reverse plug for top of gearbox
am i missing anything?can i use the auto ecu?and what wiring needs to be done? :) Thanks.
PopCorn
Postby demis » Wed Jun 14, 2006 11:39 pm
the auto ecu works fine
the od light will start flashing to say tranny is not conected but you just remove the bulb from the dash
the other wiring is just to conect the plug for revers swithc on the top of the gear box and the wire going to the starter motor needs to be solded to gether where it normally go into the auto tranny to stop you from starting the car with out it in park
-modify loom
-pivot stud- normally on the gear box already
-thrust bearing- will come with new clutch kit
-clutch
-gearbox
-pedal box
-brake pedal
-gear box top mount
-interior trim
gear box oil
clutch fluid
EX 1984 Corolla FX GT (AE82) 1st gen 4age
EX 1996 Corolla BZ touring (AE101) 5th gen 4age -LSD
EX 1997 Carib Z touring (AE111) some 4afe muck
Ex 2000 Fielder S (ZZE122)- Its BIG RED
2002 Corolla Ts (ZZE122) Mr ~ Ts
demis
Postby PopCorn » Thu Jun 15, 2006 12:02 am
awesome thanks for all your help :D
PopCorn
