AE111 SP1 signal
Postby johntramp » Tue Nov 21, 2006 3:05 pm
slighty_sykotic wrote:
maxium wrote:hey matt wot afftect will running no speedo sesnor have on the ecu operation?
a freind has a 20vblacktop in a escort race car and is having a few issues getting it to run right
it has a lower rev limit and brings up a warning light
No, its farrrrr worse than that.
It wont run smoothly (at least with a auto ae111 blacktop ecu).
I had this problem in my aw11 with a blacktop.
Massive hesitation, feels like its missing really really bad.
Fixed instantly when I hooked up the wire.
--Sykotic
oh really. is it important to have an accurate speed signal?
johntramp
Postby slighty_sykotic » Tue Nov 21, 2006 4:20 pm
I don't think so, as I doubt my aw11 gearbox is putting out the same as the blacktop gearbox in the car it came out of (maybe, I might be wrong).
I think it just needs any signal. Make one with a 555 timer and circuit, or buy a thing from Matt.
--Sykotic
slighty_sykotic
Postby johntramp » Tue Nov 21, 2006 8:22 pm
do you have any info on how to set up a 555 circuit?
johntramp
Postby matt dunn » Tue Nov 21, 2006 8:24 pm
johntramp wrote: is it important to have an accurate speed signal?
The signal is important, but the accuracy is not,
and it only seems to affect the BT's from what I can tell
as the early 4AGE's will throw a code and bring on th light but wont affect them.
Postby slighty_sykotic » Wed Nov 22, 2006 11:36 am
I agree with that, i've run my 4agte on a 4agze ecu, and a couple of std 16v, and none of them had the speed sensor hooked up, and they all ran fine (with the check light on).
slighty_sykotic
Postby johntramp » Sat Dec 02, 2006 1:39 am
This is what I have come up with for the 555 chip. Is there anything I can do to improve this?
johntramp
Postby sergei » Sat Dec 02, 2006 2:13 am
Decrease values of the RC chain resistors and increase capacitance, 10MOhm is too big for this oscilator to work stable.
Postby johntramp » Sat Dec 02, 2006 10:42 am
alright :) I was kinda just working around the components i found lying around
johntramp
Postby sergei » Sat Dec 02, 2006 12:36 pm
Postby johntramp » Sun Dec 03, 2006 1:10 am
I don't have a speed signal as my car was originally 3AU, thats why I need to fake one. That is using the output from dash and modifying it.
johntramp
Postby JRS » Sun Dec 03, 2006 2:33 pm
you could use a flip-flop to half the freq of the signal. as long as you dont plan on going over 360 km/h lol
meh.....
JRS
Postby johntramp » Sun Dec 03, 2006 5:21 pm
I don't think you understand. I have no signal and I need to create one, from nothing. This has nothing to do with removing the speed cut, it is to get the engine running better because at the moment it is missing which apparently is caused by not having a speed sensor.
johntramp
Postby johntramp » Mon Dec 11, 2006 11:29 pm
I built that circuit to oscillate at around 60Hz and put it into the car today... 8O it made a huge difference, honestly well over 50kw more power
:D
johntramp
