stopping a blacktop from spitting rods
Postby strap-on » Sun Feb 11, 2007 1:30 pm
Sorry for flogging a dead horse i just found this thread on a search (yes i know sometimes i amaze myself)
wouldnt it be better to replace with silvertop rods then lighten things such as the flywheel, crank pulley and the car, because then the rods could handle a little more and the weight doesnt matter?
strap-on
Postby Mr Revhead » Sun Feb 11, 2007 3:42 pm
ah.... yeah thats what is being said.....
Postby strap-on » Sun Feb 11, 2007 4:20 pm
mint just checking i had the right idea,
strap-on
Postby matt dunn » Sun Feb 11, 2007 9:04 pm
Mr Revhead wrote:haha obviosuly after.
which would suggest it breaks on the way up.
of course is could just get fired upwards after it breaks, but its not likely to break on the way down is it.
From what i believe with rod failures in general is that at high RPM it is when you lift off that they fail,
The piston is coming up the bore at an amazing speed,
and when the throttle closes there is hardly any air in the cylinder and so the lack of actual pressure on top of the piston to slow it down aid's in the rod failure, hence they break on TDC and the piston caries on upwards.
Depending on where they break then depend on the damage.
We had a 1GGZE throw a rod at an endurance race.
They driver hooked 2nd at the hairpin a bit to early and over revved it.
the rod broke right at the top by the gudeon.
Because the remaining rod length was so long it could not drop down below the bottom of the bore so just slid up and down in the block.
the only symptoms the car showed was it missed on one cylinder.
After checking spark, plugs, injector etc etc was not until we stripped the motor we found it.
How ever if the rod can drop down below the bottom of the bore it will move out to the side at BDC and then when it comes back up again it will punch holes in things,
as Mr Revhead may remember with the same 1GGZE having 3 places in the block where you could see in one side and out the other.
Matt
Postby Mr Revhead » Sun Feb 11, 2007 9:41 pm
hehee yeah
[quote=me]how many revs were you pulling?[/quote]
[quote=matts dad]oh somewhere between 6 and 10[/quote]
:lol:
Postby RomanV » Sun Feb 11, 2007 10:13 pm
I thought engines with a rod to stroke ratio that isnt so great, would break the rods on the way down on a combustion stroke?
Postby nzae86 » Mon Feb 12, 2007 6:48 am
Simple cure, just build yourself an atlantic engine ! and revlimit it to 9000rpm :D
Your addiction to motorsport can only be cured by poverty!
nzae86
Postby RedMist » Mon Feb 12, 2007 7:44 am
nzae86 wrote:Simple cure, just build yourself an atlantic engine ! and revlimit it to 9000rpm :D
Atlantic engines are RPM limited to 9.5k anyway.
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby Stealer Of Souls » Mon Feb 12, 2007 8:56 am
Acesniper has some aftermarket rods (don't know the details but H beam rods or something like that) that are lighter than blacktop rods and are supposed to be stronger..
The answer...
Titanium.... (?!?!?!?!)
'86 AE85.5 Levin
Stealer Of Souls
Postby KinLoud » Mon Feb 12, 2007 8:11 pm
FAQ this please!
Postby AceSniper » Mon Feb 12, 2007 11:48 pm
490gram forged steel H beams with arps
abit lighter than blacktop rods.
also while surfing I came across these .... pritty cheap.....
http://www.japaneseperformanceparts.com ... -4451.html
AceSniper
