eritate wrote:A 1k is fitted with a ct20 ?
NFORCA wrote:Aparently putting a larger exhaust on helps, as does adding an intercooler if it doesnt have one already.
sergei wrote:maybe pipe in some intercooler? crank up the boost (i think they run 13psi from factory)... adjust fuel pump...
Mr Revhead wrote:oh yes cooling....
i should have mentioned that.
they do crack heads if theres even a HINT of a dodgy cooling system
so if you are gunna up the power, as mentioned fit an intercooler and look at a bigger rad and cooler thermostat
