Larger swaybars in FXGT
Postby Leon » Thu Oct 12, 2006 8:40 am
I can't recomend the adjustable one enough. Especially at that price.
It absolutely blew my mind, I raved about it, now we've got three Corolla's (maybe four?) and two Starlet's in the club all using them on autocross' and tracks, and all saying good things about them.
Postby 4-AGE 4-LIFE » Thu Oct 12, 2006 10:41 am
Definatly go for the rear bar
i put a 20mm whiteline one in the rear of my ae101 and it decreased the understear drammaticly feels almost like a go cart around the hills
Ben Threadwell
Exsus Automotive
Suspension specialists
4-AGE 4-LIFE
Postby crispy'86 » Thu Oct 12, 2006 12:08 pm
Alright then thanks heaps for all your input people. Looks like i'll be saving even more money now
crispy'86
Postby TRD_ZERO » Tue Jan 10, 2012 8:18 pm
Sorry to bring this old thread up but will a ae92 rear swaybar fit a ae111?
Previous:
TRD_ZERO
Postby tsoob » Tue Jan 10, 2012 9:54 pm
larger rear bar.
Nick
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
Postby TRD_ZERO » Wed Jan 11, 2012 10:19 am
Larger rear bar? could you elaborate a little? Larger rear bar as in just the diameter or are they both not interchangable at all?
Previous:
TRD_ZERO
Postby touge_ae101 » Wed Jan 11, 2012 12:17 pm
i'm pretty certain they aren't interchangable. but what nick was referring to is ae111 has a larger rear bar as standard than the ae92.
ae111 BZR has a 18mm bar (same spec as TRD) and so does the ae101 gtz if you are looking for a good cheap upgrade.
touge_ae101
Postby Mr Revhead » Wed Jan 11, 2012 12:34 pm
Will not be the same spec as TRD
Postby touge_ae101 » Wed Jan 11, 2012 12:41 pm
Mr Revhead wrote:Will not be the same spec as TRD
standard is 18mm solid bar and TRD is 19mm hollow bar. it works out to be about the same.
touge_ae101
Postby Mr Revhead » Wed Jan 11, 2012 12:54 pm
How did you come to that conclusion?
Being at work at the moment i don't have any of my sway bar calc stuff here.
A hollow bar is stiffer than same diameter solid bar.
A larger diameter is stiffer than a smaller bar.
However wall thickness and material will have a factor as well
Postby touge_ae101 » Wed Jan 11, 2012 12:57 pm
it was discussed on here some time ago.
anyways..
touge_ae101
Postby Mr Revhead » Wed Jan 11, 2012 12:59 pm
I'm not having a go, one of us is mistaken and if it's me I'd like to be corrected!
Postby 1I1 » Wed Jan 11, 2012 1:03 pm
^ TRD tell you not to fit their 19mm bar to a BZR lol
Superstrut AE101 / prefacelift AE111 have a 17mm rear bar (some may even have a 16mm rear bar)
AE111 BZR's have a 18mm rear bar
TRD Clicky >>Here
1I1
Postby Mr Revhead » Wed Jan 11, 2012 1:12 pm
Yeah but that could be for several reasons.
Would be keen to see actual proper figures for them
Postby 1I1 » Wed Jan 11, 2012 1:16 pm
http://trdparts.jp/english/parts_stabilizer.html
Rear
(Except model after 97.4 with Super strut suspension)
φ=19.1 Hollow type
27% stiffer than OE
And doesn't matter if the car is superstrut or not, the rear bars are interchangable on AE101/AE111
TRD Clicky >>Here
1I1
Postby tsoob » Wed Jan 11, 2012 2:56 pm
I fitted the larger front bar to my car first, made it drive like a pig.
Put the matching 18mm adjustable whiteline in and it became a little buggy to drive.
You can feel the rear of the car working now!
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
tsoob
Postby Grrrrrrr! » Wed Jan 11, 2012 5:26 pm
Mr Revhead wrote:A hollow bar is stiffer than same diameter solid bar.
Not unless the laws of physics have changed recently, or you are talking about different materials
Hollow bar stiffer than same weight solid bar for sure.
Grrrrrrr!
Postby Malcolm » Wed Jan 11, 2012 6:33 pm
Grrrrrrr! wrote:Hollow bar stiffer than same weight solid bar for sure.
What if the hollow bar is longer? :P
Users browsing this forum: Google [Bot] and 33 guests
