Recommended 4age valve springs...
Postby Pies » Sun Oct 29, 2006 9:26 pm
i have some trd ones i might be willing to let go of for a little less than revhead will do em. unused and still in the box
Current Rides:
Pies
Postby no_8wire » Sun Oct 29, 2006 9:28 pm
aren't they for na application though?
no_8wire
Postby Mr Revhead » Sun Oct 29, 2006 9:42 pm
how much boost u going for?
stock springs are used by many for 18psi and 8k rpm.
i think youd need to be pretty damn serious for anything more than TRD group A valve springs
Postby no_8wire » Sun Oct 29, 2006 9:43 pm
20psi if not more...see when knock starts....
no_8wire
Postby Bazda » Sun Oct 29, 2006 9:56 pm
I think for what boost I run the TRD ones were just under our calcualtions for what we needed.
Thats why i went to performance springs which were just over what I needed, this is all relative to the 20v not 16v though.
Postby CAMB01 » Sun Oct 29, 2006 10:05 pm
I'm using crow cam springs in my 16v which have 85psi seat pressure.
The cams im using required at least 70psi seat pressure.
and these cams make good power upto around 7500rpm
1993 Mitsubishi EVO 1 Racecar
1989 AE91 FX-ZS (Previous)
Custom Works Automotive
http://www.HCCC.org.nz
CAMB01
