Black-Top 4A-GE Questions?
Postby Chickenman » Fri Oct 27, 2006 11:42 pm
sergei wrote:and the way they use or implies it either has to be same capacity or power.. So in other words if it is 1600cc it does not matter what power does it make ;).
You've misinterpreted that Sergei. It just means the engine has to be either 1600cc or less and it must also make the same power or less to not need a cert.
You WILL need a cert if you swap a B/T into a car that had a red or bluetop engine previously... same if you put bigger cams in and make 20% more power (not that anyone could tell).
Baby Jesus
Chickenman
I Am The Walrus!
Postby johntramp » Sat Oct 28, 2006 12:24 am
I am pretty sure sergei is right... it would say "is of the same or less capacity and power output" otherwise.
johntramp
Postby Chickenman » Sat Oct 28, 2006 12:31 am
johntramp wrote:I am pretty sure sergei is right... it would say "is of the same or less capacity and power output" otherwise.
Yeah I guess, it means you could put in a 2litre engine if it made less power?
That shit is whack
Baby Jesus
Chickenman
I Am The Walrus!
Postby johntramp » Sat Oct 28, 2006 12:53 am
chances are then it would fail (f) though
johntramp
Postby RedMist » Sat Oct 28, 2006 1:23 pm
That sh*t is whack
Or you could put in a 400hp turbo 1600cc engine.
.... but then again in all cases you can bet the Law will be read as an or... which its fairly obviously supposed to read.
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby sergei » Sat Oct 28, 2006 1:54 pm
Well they state that "of same induction", so no for turbo 400hp..
Postby Chickenman » Sat Oct 28, 2006 2:32 pm
sergei wrote:Well they state that "of same induction", so no for turbo 400hp..
yeah redmist.. get it right ffs.
:roll:
Baby Jesus
Chickenman
I Am The Walrus!
Postby soopachargen » Sat Oct 28, 2006 2:38 pm
document wrote:is of the same design and casting of cylinder block and cylinder head
and a blacktop has a different head to a bluetop... :roll:
When in doubt, down and out.
soopachargen
Postby SUBARUCONVERT » Sat Oct 28, 2006 3:38 pm
also the 20v makes more power so needs a cert, and is of differnt head design, also doing FE-GE conversions require a cert " differnt head design.
SUBARUCONVERT
Postby RedMist » Sat Oct 28, 2006 10:46 pm
:roll:
You know I'm too old to read.
RedMist
Postby Chickenman » Sat Oct 28, 2006 10:53 pm
All I know is... you've still gotta lotta love to give redmist... a whole lotta love.
Way down inside :o
Baby Jesus
Chickenman
I Am The Walrus!
