Wof Issue - Remedy play in L.F. Wheel bearing
Postby Bling » Thu Nov 09, 2006 10:00 pm
how did you fix the bearing?
Postby BZG_UNIT » Fri Nov 10, 2006 9:53 pm
turneed out bearing just needed adjusting.. not replacing (Like Automotive One Stop insisted) .. got warrant after that .. thanks to tim from octane performance in palmy :) .. tints had to be light metered and read 36.6% .. finally got shit sorted and legalised
1997 Toyota Trueno
1990 Toyota Trueno GTZ
BZG_UNIT
Postby Bling » Fri Nov 10, 2006 11:48 pm
adjusting as in tightening? :lol: good to hear it got sorted anyway
Postby sergei » Fri Nov 10, 2006 11:59 pm
BZG_UNIT wrote:turneed out bearing just needed adjusting.. not replacing (Like Automotive One Stop insisted) .. got warrant after that .. thanks to tim from octane performance in palmy :) .. tints had to be light metered and read 36.6% .. finally got sh*t sorted and legalised
Most likely hub is loose relative to bearing. Which means it might reappear again...
Postby BZG_UNIT » Sat Nov 11, 2006 11:18 pm
sergei wrote:Most likely hub is loose relative to bearing. Which means it might reappear again...
yeh itll need replacing sometime soon.. maybe next wof
1997 Toyota Trueno
BZG_UNIT
Postby Simon K » Sun Nov 12, 2006 1:49 pm
Regarding the tint, if there is any light "factory" tinting to the glass it will be darker when fitted with tint film. In that case you need something a little bit lighter than the "tick approved 35%" stuff to stay legal.
The VZR has a slight tint to the glass already and 35% will take it just over the limit...re registering it as a commercial vehicle isn't an option(as much as I'd love black out tints)due to having to remove the back seats/belts etc.
Simon K
TS Wannabe
Users browsing this forum: Google [Bot] and 32 guests
