180km/h speed cut
Postby mr2--mad » Fri Nov 10, 2006 2:18 pm
I could be in Tauranga this weekend if you would give me hand? .
mr2--mad
Postby fivebob » Fri Nov 10, 2006 2:18 pm
mr2--mad wrote:Can I run a 13.2 V wire straight from the battery to pin 14? and just ground the other two pins?
No Pin 14 is +5v not +12v, you'll burn it it out trying to run that much voltage to it.
Use the "VC" pin on the the 16 pin connector for a +5v signal.
3sgte 09661------.If I took it off the boot, would it be on the underside? oh well ill look any way .
Nah it's the number on the end I need. Doesn't matter anyway as you can take the top off the ECD and read the pin assignments on the circuit board.
SPD is on the 22 pin connector, VC +5v is on the 16 pin connector.
Postby fivebob » Fri Nov 10, 2006 2:19 pm
mr2--mad wrote:I could be in Tauranga this weekend if you would give me hand? .
Nope I'm in Australia right now
Postby mr2--mad » Fri Nov 10, 2006 2:29 pm
Ok Im mega confuesd. But sounds like heaps of fun Ill go grab the I/C from dick smiths and take the top off and then post some pics before I do anything silly
mr2--mad
Postby RomanV » Fri Nov 10, 2006 2:36 pm
I can more than likely come give you a hand with it some time, I've been through an MR2 wiring nightmare before. :lol:
Wouldnt take long to get back. :lol:
Postby mr2--mad » Fri Nov 10, 2006 4:23 pm
Thanks RomanV keen as for a hand with wiring this tiny little I/C up,Ok fivebob i see the pin assignments and i have the D/S part ,what do i cut and what do i join?
mr2--mad
Postby fivebob » Fri Nov 10, 2006 4:39 pm
Cut the wire going to the SPD pin ( should be a purple colour) attach the wire from the ECU end to pin #12 and the other end (from the speedo) to Pin #1.
Tap into (i.e. do not cut it) the VC wire for a 5v source and attach that to Pin #14.
Wire Pins #2 & #7 to earth (either the ECU earth or chassis ground shouldn't matter which)
Postby mr2--mad » Fri Nov 10, 2006 4:50 pm
OK awesome 8) just a couple Questions . How did you number the pins on the I/C? and by attach you mean solder ?and to tap into the VC wire just remove the plastic without damaging the wire and then solder a wire on .Then tape it up ,
mr2--mad
Postby mr2--mad » Fri Nov 10, 2006 5:07 pm
][/URL]Image
mr2--mad
Postby MR2SIK » Fri Nov 10, 2006 6:01 pm
If I knew there was a demand for speed cut defenders I coulda sold you my one :roll:
Its been in my car for as long as I've owned it, and its never been used. You'l crack 180 once or twice then either get busted by the cops go to jail and get ass raped by bubba, crash die, go to hell and get ass raped by demons with pineapples, or go wow so thats what going past 180km/h feels like, and never do it again...
And after reading many previous 'anti boyracer' posts on this forum, I'm suprised so many people are helping him out when its blatently obvious this is going to be done on the street :?
2011 Ford Mondeo tdci.
1990 MR2 GT garage queen
MR2SIK
Postby RomanV » Fri Nov 10, 2006 6:26 pm
MR2SIK wrote:If I knew there was a demand for speed cut defenders I coulda sold you my one :roll:
Postby mr2--mad » Fri Nov 10, 2006 6:34 pm
:D :) :lol: . Seriously though Trackday at Puke coming soon. Speedcut would ruin my fun and under cutting the price of an HKS item buy 2450% sounds so rad
mr2--mad
Postby sergei » Fri Nov 10, 2006 6:46 pm
you numbered pins wrong.
loocking at the top of an ic (where the model is written ;)). start counting from dot/tab/indent like this:
Postby MR2SIK » Fri Nov 10, 2006 6:48 pm
mr2--mad wrote:Im actually going to some track days at Puke soon, and since its my car :? why you care.
Yes it is your car and you can do what you want with it, and track days are all good, you just didnt mention anything about them in your previous posts.
My 'issue' if you can call it that is that you were talking about doing this on a public road.
And I simply brought up the fact that previous attitudes on this site regarding such things have been along the lines of 'dont do it its wrong bla bla bla' I bring it up in a light hearted way and I still get flamed for it. :roll:
MR2SIK
Postby Dell'Orto » Fri Nov 10, 2006 6:49 pm
mr2--mad wrote::D :) :lol: that guy sounds like a very OLD police women .No six lane motorways in Nelson ah
Whats that got to do with it? 6 lanes or not, 180kph+ on NZ roads isnt particularly sensible nor safe.
Hang on, isnt the SW20 speedcut higher than that? I'm sure mine never cutout until it was past 180 on the stock ECU.
Postby mr2--mad » Fri Nov 10, 2006 6:52 pm
Correct Ill save it for the track !.Thanks sergei You rule, yeah mine seems to change i ve seen 230 on the speedo before it cut and then on same track day :) it started cutting out at 180 :?
mr2--mad
Postby MR2SIK » Fri Nov 10, 2006 6:53 pm
If you can believe the net, its around 190ish
MR2SIK
Postby slighty_sykotic » Fri Nov 10, 2006 9:07 pm
think you may find all the mr2s cut at the same speed, about 180. its just your speedos arnt accurate.
slighty_sykotic
Postby fivebob » Fri Nov 10, 2006 9:30 pm
slighty_sykotic wrote:think you may find all the mr2s cut at the same speed, about 180. its just your speedos arnt accurate.
All the ones I've driven cut at 5500 in 5th, or just off redline in 4th, both of which work out to around 200km/h :wink:
Postby slighty_sykotic » Fri Nov 10, 2006 9:52 pm
Ok, then at 200 then instead of 180. But were all the speedos reading exaclty 200?
Reason for that, is ive driven 3 ae101s to speed cut, and all cut at around 190ish (working out with revs, gear ratios and wheels), but the speedos varied from 195 to 220ish. (mine was the the 220ish, it was horribly out, yet at 110 my speedo read 109ish (radar trailer proven)).
--Sykotic
slighty_sykotic
Users browsing this forum: Google [Bot] and 31 guests
