Boost Gauge...How high above desired level?
Postby diss7 » Fri Dec 15, 2006 5:00 pm
Mmm, Boost wrote:As long as its accurate and your boost control is sweet, then why bother?
Wtf?
How the hell will he know if its running 20, or over 20 if the gauge only goes upto 20? :roll:
If you're cheap and want to upgrade your gauge to drift-spec, rotate the face plate so that the needle rests where -5psi would be, so when its boosting 5psi, the needle now rests on 0.
This means you can now use the gauge to 25 psi.
Disclaimer - Ive never done this, and don't intend to. - Get a new gauge.
diss7
Postby Dell'Orto » Fri Dec 15, 2006 5:10 pm
Well generally if the boost is controlled properly, it'll go to 20psi and sit on it. If he wants to run over 20psi then he'd want a bigger gauge.
Seeing as he "only" wants 20psi, then one that reads that high would be fine :roll:
Postby no_8wire » Fri Dec 15, 2006 6:24 pm
ok sweet...anyone want a boost gauge that reads to 20psi then?
:lol:
no_8wire
Postby Adydas » Fri Dec 15, 2006 6:27 pm
Anyone with the money to be runnign 20+ PSI of boost needs a classy boost guage, So i now highly reccomend the good ness of an a eletrical guage such as Defi or Apexis range that lets you record and playback your bad ass boost levels.
Adydas
Postby no_8wire » Fri Dec 15, 2006 6:45 pm
classy?
This is classy
8)
But not high enough...
no_8wire
Postby CozmoNz » Fri Dec 15, 2006 7:36 pm
thats not classy, thats repco, i had one in my aw! (mr2sik put it in i think)
anyway, those clips are sort after apparently, better than those shitty cup mounting things.
Rayne For President!
CozmoNz
Postby no_8wire » Fri Dec 15, 2006 8:29 pm
haha say yes to chrome cups people!
I like the white dials...so sue me
no_8wire
Postby diss7 » Fri Dec 15, 2006 9:32 pm
Mmm, Boost wrote:Well generally if the boost is controlled properly, it'll go to 20psi and sit on it. If he wants to run over 20psi then he'd want a bigger gauge.
No, you're still not getting it.
The gauge might tell him that the controller is holding it at 20, but it might be holding it at 22, or creeping past 20 etc etc.
diss7
Postby HELBND » Fri Dec 15, 2006 9:36 pm
no_8wire wrote:haha say yes to chrome cups people!
those are black dials... with white markings :P
HELBND
Postby IH8TEC » Fri Dec 15, 2006 9:41 pm
The gauge might tell him that the controller is holding it at 20, but it might be holding it at 22.
wtf, get an accurate gauge, the boost guage does actually go over the 20psi line, not good for it, but thats why you turn it up in incriments to get that level
anyway, get a bigger gauge and be done with it
Postby no_8wire » Fri Dec 15, 2006 9:43 pm
well obviously I meant white dial markings... :lol:
:oops:
hahaha
What are autogauges like anyway? the electric ones?
no_8wire
Postby Dell'Orto » Fri Dec 15, 2006 10:20 pm
You've never run higher than 20psi on a 20psi gauge then huh.
