tdc/ bluetop cams
Postby bluemaumau » Sat Jan 06, 2007 9:05 pm
Postby RedMist » Sat Jan 06, 2007 9:34 pm
Don't quote me on this.... actually don't go anywhere near quoting me. However I had thought that the ZE cam pulleys were indexed differently. IE the keyways and the marks were different to that of the 4age.
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby bluemaumau » Sat Jan 06, 2007 11:33 pm
i dont think they are as i put the ze cams back in and there still a cm off. :evil:
Postby Crucible » Sun Jan 07, 2007 1:03 am
dude....
On tdc, get No 4 cyl rocking, You want the ex lobes and inlet lobes facing the centre, that would mean the No1 is on Comp, Power stroke.
timing marks should become obvious really once youve done that..
the exhaust cam dowel is facing down not up with bluetops......you shouldnt have both dowels up, if you have then one cam is out.
Crucible
Real Life Mechanic
Postby IH8TEC » Sun Jan 07, 2007 1:41 am
run the gze cam gears man. and tnt, are you meaning the dowl on the end of the cam?
Postby bluemaumau » Sun Jan 07, 2007 10:49 am
i havnt done anything yet as i dont have a adapter to torque the caps down.
but currently the inlet dowel is at 12oclock and exhaust is at 5 oclcok
Postby bluemaumau » Sun Jan 07, 2007 10:57 am
if it makes any difference, the little markings on the gears are at 1 oclock on the inlet and 11oclock on the exhaust (compared to marking on the backing plate)
Postby Crucible » Sun Jan 07, 2007 10:57 am
IH8TEC wrote:run the gze cam gears man. and tnt, are you meaning the dowl on the end of the cam?
Yeap , the dowels that locate the c/belt pulleys
If you get it rocking on 4 then the dowels should be 90 deg from each other, inlet 12 oclock and exhaust 6 oclock, they should be straight up and down. The exhaust valve should have just closed fully and the inlet just about to open (rocking).
Crucible
Real Life Mechanic
Postby bluemaumau » Sun Jan 07, 2007 11:00 am
6 oclock are you sure on that?
Postby Crucible » Sun Jan 07, 2007 11:03 am
bluemaumau wrote:6 oclock are you sure on that?
Can you get some pics up???
check the position of the lobes first If they are where I mentioned then the cams are sitting in the right position not 180 out. The exhaust cam dowel is around 6 oclock "from memory", if it is sitting around 5 oclock then the pulley notches should be both sitting at 12 oclock.
check the lobes first before worrying about anything else.......
Crucible
Real Life Mechanic
Postby bluemaumau » Sun Jan 07, 2007 11:18 am
1st pic showing inlet LHS
2nd pic showing exhaust wheel(11oclock)
3rd pic showing inlet wheel(1 oclock)
4th pic inlet wheel with baqcking plate
hope that helps
Postby Crucible » Sun Jan 07, 2007 11:22 am
Did you check the lobe position on no 4?, can you get a pic of that?
Crucible
Real Life Mechanic
Postby bluemaumau » Sun Jan 07, 2007 11:35 am
inlet no 4
exhaust no 4
Postby Crucible » Sun Jan 07, 2007 12:04 pm
Ok sweet, the cams are sitting on the correct side of the followers. Put the inlet cam pulley mark (Pulley mark not cam dowel) in line with the mark on the back plate and same with the exhaust cam so both are at 12 oclock, the exh cam (dowel) will actually be at 5 oclock not 6.
that should be bang on, just rotate the crank twice once the belts on and double check the marks.
sweet
Crucible
Real Life Mechanic
Postby bluemaumau » Sun Jan 07, 2007 12:06 pm
ok, weird, did anyone else have this problem?
cheers tnt and brendon.
