Changing Rev limit on 4AGE blue top.
Postby sergei » Mon Jan 22, 2007 9:16 am
No way you will have valve bounce on 4AGE at 7000-8000rpm, it has to be somewhere arround 10k mark, my 20v revs till 9000rpm and no valve bounce (just a nasty fuel cut at the end, slamming brakes feeling)... BTW it has stock springs in it.
I had a redtop it revved till 8k.
You might have lower rev limiter due to SPD sensor not connected (wich is fed from dash).
Postby NA Drifter » Mon Jan 22, 2007 2:09 pm
Stealer Of Souls wrote:
NA Drifter wrote:Sometimes it cut at 7200rpm, 7400rpm, sometimes 7800rpm still std ecu..
Do you mean the same ecu unit or different ecu units? I always thought mine went up to 7800 before cutting, but when I was on the dyno the sheet came back with a 7300ish cut. I thought it was weird, so worked out how fast it would've been going in that gear at that RPM and sure enough, 7300ish when it cut...
Does it have to do with temperatures and that? Perhaps cuts lower if engine cold????
Everything same every time... but just different rev limit.. donno why... also have a SAFCII for reading the max rpm output... could be the way the car been driven, temperature.. etc?
Keith
NA Drifter
Postby sergei » Mon Jan 22, 2007 2:11 pm
It is defenitly temperature dependant. (On colder it is lower).
Postby Caveman » Mon Jan 22, 2007 7:44 pm
sergei wrote:No way you will have valve bounce on 4AGE at 7000-8000rpm, it has to be somewhere arround 10k mark, my 20v revs till 9000rpm and no valve bounce (just a nasty fuel cut at the end, slamming brakes feeling)... BTW it has stock springs in it.
This was my thought, lower rev limit while the car is sitting still
which dyno was it? a lot guess gear ratios to overlay rpm, usually its ralative to wheel speed. Unless they connected up to your coil...
AW11 Track Toy
Formerly known as 1998
Caveman
Postby Stealer Of Souls » Wed Jan 24, 2007 9:06 am
It was at Torque Performance.
And yeah, I think it was done off roller speed with a ratio gathered from reading roller speed vs tacho at lower rpm...
Either way, I am reasonably confident that it's right and the cut was around 7300, as that matches my calculation using my gear ratios.
'86 AE85.5 Levin
Stealer Of Souls
Postby pc » Wed Jan 24, 2007 9:27 am
My 3 bluetop ECUs always cut at 7600. I have one jap manual, jap auto, and one that i've been told is a NZ manual (but I don't think it is).
red car
1/4 mile - 14.683s @ 91.83mph
Manfield - 1:24s
pc
Postby big_boy » Wed Jan 24, 2007 10:10 am
they are speed cut tho according to other fourms 7225RPM un loaded for manual & 7330RPM of an auto also they are cold limted in stages of 5000,6000,7000RPM im unsure of the tempture at withc these are cut off but they deffently are
& 7850RPM in the max under load
for sale EE90
big_boy
Postby Stealer Of Souls » Thu Jan 25, 2007 8:23 am
sergei wrote:It is defenitly temperature dependant. (On colder it is lower).
How did I miss this post?!?!?!?
But this would explain it. The car had managed to cool down before being put on the rollers...
'86 AE85.5 Levin
Stealer Of Souls
Postby Mr Revhead » Thu Jan 25, 2007 11:04 am
ok
so we have established the difference between valve bounce and rev cut....
can anyone answer the original question?
Postby pc » Thu Jan 25, 2007 11:19 am
Ahhh yes the original question. Years ago I had heard that getting an NZ new ECU will raise my rev limit, as well as removing the speed cut. I bought an ECU and was told it was an NZ new. I didn't notice any difference in revs except the the fuel map in the middle near TVIS change over (dyno plot reference) is bad and I loose lots of power. I went back to my standard JDM ECU a couple of months ago and the car goes better.
So if you get the right NZ new ECU, maybe it will raise the rev limit.
red car
Manfield - 1:24s
pc
Postby Stealer Of Souls » Thu Jan 25, 2007 11:19 am
Mr Revhead wrote:ok
Good point...
Although it may be a moot point. If the rev cut varies according to engine status (hot/cold, moving/stopped, etc) then what I need to do is get a dyno run with the engine at operating temperature (and find some way of making a speed signal for the ecu - damn that AE85 dash).
'86 AE85.5 Levin
Stealer Of Souls
Postby Brick » Thu Jan 25, 2007 11:34 am
you cant really go by the rev counter on the dash, ysterday when i was driving along the link hand controller said 2,700rpm but the dash said 3,000rpm, and as it gets higher it gets less accurate. I use to think my old Fx rev limiter was at 8,200 :lol:
Brick
I know Kung Fu
Postby big_boy » Thu Jan 25, 2007 12:31 pm
you can get this thing for link ECU`s for about $40 that splits the spedo drive in 2 one eletronic drive for the link ( or in your case the ECU) & one manual drive for the spedo if that would help
for sale EE90
big_boy
Postby TTEETT » Thu Jan 25, 2007 12:45 pm
Just been for a drive to test where my GT hits its rev limiter, seems to be at 7,800rpm, and has no speed cut limiter. Its NZ assembled, I have a spare NZ-GT ECU in my shed for a rainy day, I have been told they are different before but never really believed it, the import blue-top motors normally have an censer on the exhaust manifold too don’t they?
TTEETT
Postby Stealer Of Souls » Thu Jan 25, 2007 1:35 pm
big_boy wrote:you can get this thing for link ECU`s for about $40 that splits the spedo drive in 2 one eletronic drive for the link ( or in your case the ECU) & one manual drive for the spedo if that would help
That is useful. Even if I don't need the speedo output for the ecu, I do need to run some other stuff I've got. Any ideas where to check it out?
Brick wrote:you cant really go by the rev counter on the dash, ysterday when i was driving along the link hand controller said 2,700rpm but the dash said 3,000rpm, and as it gets higher it gets less accurate. I use to think my old Fx rev limiter was at 8,200
May be true in some cases. In my case the tacho reads fine down low. Because it's an AE85 dash it starts to go bad after about 5.5k. Below 5.5k usually everything meshes up almost perfectly with calculated values.
TTEETT wrote:Just been for a drive to test where my GT hits its rev limiter, seems to be at 7,800rpm, and has no speed cut limiter. Its NZ assembled, I have a spare NZ-GT ECU in my shed for a rainy day, I have been told they are different before but never really believed it, the import blue-top motors normally have an censer on the exhaust manifold too don’t they?
Mine has an exhaust O2 sensor. but it's dead... And it turns out the bluetop ecus don't care what the o2 sensor says anyway. They determine fuelling purely from maps.
'86 AE85.5 Levin
Stealer Of Souls
Postby matt dunn » Thu Jan 25, 2007 10:50 pm
NZ new dont have speed limiters,
and have a fuel mixture adjuster under the bonnet instead of a O2 sensor.
Postby suberimakuri » Thu Feb 01, 2007 2:54 am
without reading every post:
Wire up an aftermarket ecu and you will find that the factory dash under reads at that sort of rpm. Hence why some cars revlimit at 7300 and others at 7800. Common.
Some dashes are better than others.
ECU's are all the same for each model/product number on the ecu.
On your motor, the ECU has fuel cut only at 7800. Fit aftermarket or adjustable limiter if you want more revs. gah.
なんでまたStealer_of_Soulsのポストを読んじゃかったかな。。
suberimakuri
Postby Stealer Of Souls » Thu Feb 01, 2007 8:15 am
Karl_Skewes wrote:without reading every post:
Cheers Karl.
My 7300 was from the dyno, not read from my dash (can't read from my dash cause it's a poos dash).
Can you suggest what to get to adjust the limiter? IE what to buy/build/steal.
What's the last line... don't make me get it translated...
'86 AE85.5 Levin
Stealer Of Souls
Postby matt dunn » Thu Feb 01, 2007 12:40 pm
Stealer Of Souls wrote:My 7300 was from the dyno, not read from my dash (can't read from my dash cause it's a poos dash).
How did the dyno know what revs you were doing,
they probably entered in a gear ratio and adjusted it to read the same as your revcounter, which if he entered in 1000rpm and it was doing 1100,
make the dyno read 10% out so out by about 700rpm at 7000.
You can buy aftermarket limiters to lower the rev limit but you cannot make the limit higher.
There is no way of upping the RPM limit that is set inside a particular Toyota ECU.
Some ecu's may or may not have different limits,
( supposedly FWD have a higher limit than RWD)
but have not done enough to confirm this.
Matt
Postby Stealer Of Souls » Thu Feb 01, 2007 4:32 pm
matt dunn wrote:How did the dyno know what revs you were doing,
Yeah. They probably entered the number by doing just that...
BUT... I check the numbers against calculated values... and it was bloody darn close.
According to the calculated values with 4.1:1 diff, 1.435:1 gear ratio (K50), 195/50-15 tyres.
7300rpm 3rd gear is 134.7kph.
The dyno road speed at the limiter was approx 133kph. And the dyno RPM was about 7250RPM.
That's too close to be coincidence.
So regardless of how they set the readout, unless there's a 10% variance in the dyno road speed it did limit at approximately 7300.
I assume the ECU does cut based upon the frequency it receives at it's RPM input?
Perhaps I can just build a circuit to play trickster...
'86 AE85.5 Levin
Stealer Of Souls
Users browsing this forum: Bing [Bot] and 8 guests
