Belts on 4agze
Postby AE82 FXGT » Mon Mar 05, 2007 7:54 pm
ae93_sx wrote:I took the whole bracket that holds the tensioner pulley off. This is a bitch of a job because you need to remove the aircon, alternator and PS pump to get the bracket off. Took maybe an hour or so.
How the hell did get it off in an hour?
I've been trying for ages now.
I've found 6 bolts/nuts holding the bracket on adn I can get the bottom to move a bit. Can anyone confirm that there is 8 bolts/nuts holding the bracket?
AE82 FXGT
Postby bluemaumau » Mon Mar 05, 2007 7:57 pm
its quite easily a 2hour job with lots of stuffing around, i cant confirm but as i previoulsy said i think theres 8.
4 are nut/studs and 4 are bolts.
they are geometrically postioned so not in random places if you catch my drift,
98% on there being 8 bolt/nuts however
Postby AE82 FXGT » Sat Mar 10, 2007 4:42 pm
Woohoo I got it off, was missing one bolt right near the exhaust manifold.
I then smashed a socket to the offending nut and got it off.
Now does anyone know what sizes the belts are (factory crank pulley)?
The local repco guy told me theres a couple variants (I told him ae101 4a gze), now I know there are only 3 belts yet he listed:
S\C belt : 5pk0940 OR 5pk0840
Waterpump : 5pk0990 (how can the waterpuump belt be different to the SC one?)
P/S : 3pk0635 (I'm sure its supposed to be a 4pk)
Aircon : 4pk0875 OR 5pk0965
I know I can take my belts in and match them up (which I probably will now), but I can't do that to the AC one because I cut it off (tensioner was $&#$%).
Will it be the 5pk or the 4pk?
AE82 FXGT
Postby slighty_sykotic » Sat Mar 10, 2007 5:00 pm
have a look at the pulley, and count the teeth, 4 pk or 5 pk reffers to the amount of "grooves" on the pulley/belt. Ethier 4 or 5 ridges.
slighty_sykotic
Postby AE82 FXGT » Sat Mar 10, 2007 5:12 pm
I should have been able to figured that out myself :oops:
Thanks man.
AE82 FXGT
Postby Zak » Sat Mar 10, 2007 5:13 pm
Just measure your cut belt and count the groves, being cut just makes it easier :wink:
*pk is your groves then **** is your length
so 4pk0875 is 4 groves and 875mm long
Zak
Postby AE82 FXGT » Sat Mar 10, 2007 7:16 pm
Zak wrote:Just measure your cut belt and count the groves, being cut just makes it easier :wink:
Should I just cut all my belts and measure them then?
They're not going to be of any use anyway.
How much should I minus from the measurement to account for the new belt stretching?
AE82 FXGT
Postby Zak » Sat Mar 10, 2007 7:21 pm
You should just be able to match them to the sizes they have listed, Just take the non cut ones in and they can compare them to what they have.
You can measure the cut one, or just count the ribs, it should be the 4 or 5 one, and just get the one they have listed.
Zak
Postby AE82 FXGT » Sat Mar 10, 2007 7:46 pm
Anyone know if TGP belt prices are reasonable compared to repco gates belts at trade price?
Can't wait till monday to get a reply from revhead.
AE82 FXGT
Postby bluemaumau » Sat Mar 10, 2007 7:48 pm
prices are good, i think around 15-25buks *i think*
Postby AE82 FXGT » Sat Mar 10, 2007 7:50 pm
Hmm. sounds like I should wait and find out before I go and buy.
AE82 FXGT
Postby Zak » Sat Mar 10, 2007 7:52 pm
Standard toyota price is $35+gst, but we are a dealer, through revhead should be alot cheaper, prolly cheaper than I can get them too :(
Zak
