Caldina GT-T modifying
Postby fivebob » Sun Apr 08, 2007 5:27 pm
slighty_sykotic wrote:Your not reading any of what we are saying are you?
Just like everone else who asks the same question every month.
Guess they don't like the answer :roll:
Postby solitaire » Sun Apr 08, 2007 5:50 pm
Im sure weve all done it at some point... i know i have... i think its a maturity thing, once you get tired of bov's, monsta tachs, chromes and such you start to listen...
on topic: i thought it was widely accepted that there can be no improvement over the toyota factory bov?
AE92, KZJ120, KDJ120
solitaire
Postby fivebob » Sun Apr 08, 2007 6:01 pm
solitaire wrote:on topic: i thought it was widely accepted that there can be no improvement over the toyota factory bov?
Widely accepted on most Toyota forums, though some people will still try and change it.
The only time I'd try to change it is if it was broken. Some of them have been known to come apart, because unlike the SW20 ones, they are made of plastic :evil:
Postby no_8wire » Sun Apr 08, 2007 6:12 pm
haha sw20 BOV +1
Its the one I chose for my project when choosing a BOV
no_8wire
Postby Mr Revhead » Sun Apr 08, 2007 6:17 pm
how different is the st215 one from the sw20 one?
ie interchangable?
Postby fivebob » Sun Apr 08, 2007 6:44 pm
Mr Revhead wrote:how different is the st215 one from the sw20 one?
ie interchangable?
The SW20 one has a metal body, the flow is in the opposite direction, and I think the flange may be different, so they may not be interchangable. I'll check them next week when I get a chance.
Postby AJz » Sun Apr 08, 2007 8:25 pm
man you guys are a bunch of preschoolers :P
THIS is how i have mine set up.
(note: the air temp sensor is still hanging in its original position, i plan to move this)
I left the breather line for the rocker cover open, factory, this runs back to the stock pipe, You can sorta make out the small filter i have fitted to the idle bypass valve underneather the BOV in the last pic, this also ran back to the stock intake pipe
I had vtax :(
AJz
Postby Mr Revhead » Sun Apr 08, 2007 10:23 pm
so have you read the thread about how the dump valve works?
Postby fivebob » Sun Apr 08, 2007 10:40 pm
Hmmm, interesting place to put the pod filter, but it needs a cold air box and something to stop the water, or you'll get a performance decrease and risk damaging the engine.
FWIW a pod filter produces no detectable power increase, according to my Blitz Power Meter
Postby AJz » Mon Apr 09, 2007 12:35 am
fivebob wrote:Hmmm, interesting place to put the pod filter, but it needs a cold air box and something to stop the water, or you'll get a performance decrease and risk damaging the engine.
i knw its not the best place, but it does a darn site better than putting a pod in place of the factory airbox, Yes i need to seal it and duct to it properly, its in testing stage. Being with the aircon radiator, and the standard, you arnt left with many options for intake routing. How have you run yours fivebob, just outta curiousity ???
I had vtax :(
AJz
Postby fivebob » Mon Apr 09, 2007 12:42 am
AJz wrote:i knw its not the best place, but it does a darn site better than putting a pod in place of the factory airbox, Yes i need to seal it and duct to it properly, its in testing stage. Being with the aircon radiator, and the standard, you arnt left with many options for intake routing. How have you run yours fivebob, just outta curiousity ???
In place of the factory airbox :twisted:
Postby AJz » Mon Apr 09, 2007 12:46 am
hot air winner :twisted: very tidy might i say though
give me ur strut brace aswell.
I had vtax :(
AJz
Postby solitaire » Mon Apr 09, 2007 12:52 am
AJz wrote:hot air winner :twisted: very tidy might i say though
If its got an intercooler does it make all that much difference in reality? I would of thought that after the air has been through the turbo its and then the intercooler the actual difference would be fairly minor? (that wasnt a retorical question)
solitaire
Postby fivebob » Mon Apr 09, 2007 12:58 am
Actually no, it's not hot air at all. There's a backing plate that isolates it from the engine bay that's not shown in that picture. That, coupled with the intake for the stock airbox and some other ducting, means the air is at close to ambient.
It's only good for show, the stock one is probably more rigid. Had a rear one as well, but that was a PITA when you wanted to load stuff in the back, so I removed it.
Postby fivebob » Mon Apr 09, 2007 1:18 am
solitaire wrote:If its got an intercooler does it make all that much difference in reality? I would of thought that after the air has been through the turbo its and then the intercooler the actual difference would be fairly minor? (that wasnt a retorical question)
Depending on turbo and I/C efficiency it's about 2.5°C charge temp increase for each 10°C difference in intake temp. Even in the worst case it's not likely to increase charge temp by much more than 10-15°C.
Postby Heapho » Mon Apr 09, 2007 1:12 pm
PM'd AJz
Heapho
Postby gttNICK » Mon Apr 09, 2007 5:41 pm
fivebob wrote:FWIW a pod filter produces no detectable power increase, according to my Blitz Power Meter
Perhaps not...
In my last car club (VASK), one member ran an experiment on a dyno. He took one reading with his original factory airbox, then swapped it with a $30 supercheap POD and got an instant 9kw increase. The 2 readings were done immediately after eachother so no changes in temp or petrol kind etc.
Caldina gt-t
gttNICK
Postby slighty_sykotic » Mon Apr 09, 2007 5:42 pm
Something was wrong that the factory airbox, ie, filter was rooted.
9kw for a change in air filter.....
BUT WAIT!!
FREE STEAK KNIVES!!.... 8O :D
slighty_sykotic
Postby gttNICK » Mon Apr 09, 2007 5:46 pm
slighty_sykotic wrote:Something was wrong that the factory airbox, ie, filter was rooted.
BUT WAIT!!
panel filter was fresh in factory box
and there were no free knives
Caldina gt-t
gttNICK
Postby slighty_sykotic » Mon Apr 09, 2007 5:48 pm
What car was it?
Not being a dick now.
Really am interested... I find that pretty hard to believe.
slighty_sykotic
