ct176 wrote:Hi guys, I need some help with axles please.
I've got a st215 gen4 motor that I'll be mating to a st202 e56 lsd gear box. I've got a set of st202 lsd axles, minus the outer cv and hub. If I were to use a complete set of axles, hubs included, off a st202 I'd end up with 5x100pcd. I'm planning on putting this all in a fwd corona that uses 4x100 pcd hubs. So my question is, can I use a hybrid of e56 and e58 axles?
Could I use e56 inner shafts that fit my gearbox, with e58 outer shafts and hubs from a gze Levin so I can retain my 4x100 pcd?
Are the two gearbox's axles compatible?
Thanks.
Rich wrote:Hey sorry to pull up a dead thread but good info in here.
Just got a Q. Has anyone successfully changed the 5th gear ratio on an e153 box? Running at 2800 rpm at 100kmph is getting old!
Users browsing this forum: Bing [Bot] and 15 guests
