Share your E## Gearbox knowledge here.......
Postby GGnz » Sun Jul 01, 2007 10:44 pm
Sweet so I've just got to find new inner shafts? Also what about the CV's?
GGnz
Postby strx7 » Mon Jul 02, 2007 7:45 am
the inner CV's are larger, but there is also different sizes depends what its out of
Postby tenyearguarantee » Fri Apr 11, 2008 4:19 pm
hey bringing back an old thread, so a vz v6 manual has a e52 (as per wikipedia) just like the ae92 gze?
so does that mean that all you would need is a suitable bellhousing to mount a vz to a gze e52?
tenyearguarantee
Re: Share your E## Gearbox knowledge here.......
Postby NickAW11 » Wed Sep 10, 2014 10:23 pm
Does anyone know if its possible to put the innards from an E154F (late model ST205 box) into an E51 AW11 supercharger box? I've heard it's possible to put the V6 camry manual internals into an AW11 box.
Cheers, Nick
NickAW11
Postby strx7 » Wed Sep 10, 2014 10:34 pm
alot of the parts would probably be swapable but i think you couldn't just change the whole guts across as i'm pretty sure the 'crownwheel' is offset differently between 2wd and 4wd boxes
Postby Grrrrrrr! » Wed Sep 10, 2014 11:11 pm
Both the E51 and E154F use the same part number for the diff crown wheel. (41221-20240). I think it'd be extremely likely that the bits could be swapped over, they are both wide E series boxes, but to do it properly you'd have to re-shim everything for the new case most likely.
4wd boxes are converted to FWD/RWD by removing the transfer case, and the 4wd diff guts and installing a 2wd diff and coverplate.
Unless you want to make silly horsepower an e58 and swap the shifter bits over might be easier?
Grrrrrrr!
Postby ®usty » Thu Sep 11, 2014 12:18 pm
E56 (E56-07C) is a 2WD gearbox - uses the same housing as the ST205 E154F but without the transfer case, has a plate on in. Is viscous LSD. Only came on 93,94 95 ST202 optional SS-II with superstrut (E-ST202- BLMVF it uses the same model code as regular SS-II only the trans/axle code is different). Wasn't on any Celica's after 95.
®usty
Postby Grrrrrrr! » Thu Sep 11, 2014 12:41 pm
E56 is a narrow gear box, E15x are all wide gear. The housings will not be the same, the gearbox is about 35mm shorter, and gears, input and output shafts are not swappable between wide and narrow boxes. (but the synchros often are)
Difference between a wide and narrow gearset.
Grrrrrrr!
Postby ®usty » Thu Sep 11, 2014 2:47 pm
®usty
Postby Grrrrrrr! » Thu Sep 11, 2014 3:05 pm
Thats the front cover only, effectively the bell housing. Which is the same as they all bolt to 3S/2C motors which share the same bellhousing bolt pattern.
The centre section is not the same.
33101-20050 (CASE, MANUAL TRANSMISSION) ST185, ST205,ST215 (4wd Wide boxes)
33101-12170 - St202 e56, 4agze e58, and Rav4 and other Narrow E series (2wd and 4wd)
Grrrrrrr!
Postby ®usty » Thu Sep 11, 2014 3:32 pm
Ahh true thanks for the clarification.
®usty
Postby ct176 » Thu Sep 25, 2014 12:11 am
Hi guys, I need some help with axles please.
I've got a st215 gen4 motor that I'll be mating to a st202 e56 lsd gear box. I've got a set of st202 lsd axles, minus the outer cv and hub. If I were to use a complete set of axles, hubs included, off a st202 I'd end up with 5x100pcd. I'm planning on putting this all in a fwd corona that uses 4x100 pcd hubs. So my question is, can I use a hybrid of e56 and e58 axles?
Could I use e56 inner shafts that fit my gearbox, with e58 outer shafts and hubs from a gze Levin so I can retain my 4x100 pcd?
Are the two gearbox's axles compatible?
Thanks.
ct176
Postby sergei » Thu Sep 25, 2014 1:51 pm
ct176 wrote:Hi guys, I need some help with axles please.
Thanks.
I am pretty sure that the splines for CV's are same regardless of stud pattern.
Postby ct176 » Thu Sep 25, 2014 4:11 pm
Thats good to know. And are the gze outer cv shafts thicker than the st202? The inner shafts are just as thick as mr2 turbo axles. But the outer cv shaft is like a tooth pic compared to the inner.
Has anyone got a set of gze outer cvs they could sell?
Here are the different thickness of the outer cv shafts from a st202 3sge and a turbo mr2.
ct176
Postby gt4dude » Fri Oct 24, 2014 10:42 pm
Any info on st205 E154F front lsd? Also swapping over 3rd and 4th gear ratios from st215w e150f?
セリカGT-FOUR ST205 中期型 (Chuuki)
200AWKW / 370NM
gt4dude
Postby Grrrrrrr! » Fri Oct 24, 2014 11:48 pm
As far as I know there is no such thing (factory or aftermarket) as a front LSD in a 4wd E-series due to the way the 4wd system works. There are stories of a front lsd that was custom made for the TTE rally cars but thats rocking horse shit and moonbeams territory.
As for the gear swap, they both use the same input and output shaft so i'd be 95% sure that 3rd and 4th should swap straight over. Probably easier to swap the entire gearset over, so long as you use the keep the st205 diff you can have a working speedo/odometer.
Grrrrrrr!
Postby strx7 » Sat Oct 25, 2014 2:22 pm
very soon i'll be attempting to modify the front diff guts to limit its slip. will see how it goes....
Postby ®usty » Sat Oct 25, 2014 8:01 pm
TRD made a front/centre LSD for the ST205/ E154f. But it's quite rare, and very very expensive.
®usty
Postby Rich » Sun Jan 18, 2015 5:47 pm
Hey sorry to pull up a dead thread but good info in here.
Just got a Q. Has anyone successfully changed the 5th gear ratio on an e153 box? Running at 2800 rpm at 100kmph is getting old!
Rich
Postby Grrrrrrr! » Mon Jan 19, 2015 12:21 am
Rich wrote:Hey sorry to pull up a dead thread but good info in here.
I'm sure its been done.. you just need to find/make a pair of gears with a taller ratio. None of the wide series boxes have a taller fifth gear option that i'm aware of.
Option 2 is find the e153 or e53 from a v6 camry and swap to a 3.93 final drive. You'd need the output shaft and the diff gear to do it.
Grrrrrrr!
