curren roll cage design.
Postby Leon » Sat Aug 04, 2007 1:55 pm
"$&#$% the dash"
The car isn't going to be anything other than a rally car from this point on ... even if you sell the car, nobody is going to look at it and go "mint car, pity you cut the dash" 8) They're going to go "my god, there's bars everywhere".
Postby RedMist » Sat Aug 04, 2007 2:02 pm
strx7 wrote:you'll soon have 20+ metres of tube into your car and think, sh1t, where did that all go to. As Leon said, occupant safety is the number 1 thing to think about when building cages. Being short you dont have the big can of worms that us tall guys have to worry about - I'm 1.93m makes seat mounting positions lots of fun I tell ya.
You must be near sitting in the boot! The struggle I have had to get to fit in the Celica is monumental! And I'm only 6'1"..... Another thing to watch with the Celica and I supect Curren is the seat height. You cant get anywhere near seeing the front corners but seeing as much of the bonnet as possible is advantageous.
I thought the drivers were being soft complaining about the room and the vision in the Celica. I can confirm both are appauling and I havent even started the engine.
My cage is all molly.
1" 3/4 32ft
1" 1/2 48 ft
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby Infinite » Sat Aug 04, 2007 2:31 pm
Ok, well i guess i could copy just the instrument cluster part and were the sterio used to go as i have allready made a custom filler panel in there from the original face. and then just have a small fibreglass dash much less weight to!, redmist u mite be interested in one to evan?, also the plates that go onto the car were they cage mounts to these only need to be welded like this Image ? not right round? correct else if they are welded right round they wont move and mite tear?
Lots
Infinite
Postby Boosted_162 » Sat Aug 04, 2007 2:36 pm
1" 3/4 32ft
1" 1/2 48 ft
The joys of being 5'8 huh? Good news for when/if i put a cage in the 185 :) (Im sure its similar in size to a ST205 inside?)
Postby Leon » Sat Aug 04, 2007 4:19 pm
Postby Mr Revhead » Sat Aug 04, 2007 6:34 pm
heres a good pic that shows what i think redmist is saying about the front roof bars
DBR9
Postby Mr Revhead » Sat Aug 04, 2007 6:35 pm
thats not the article i was reffering too, the one i saw was in the MSNZ mag i think
Postby RedMist » Sat Aug 04, 2007 7:15 pm
Mr Revhead wrote:heres a good pic that shows what i think redmist is saying about the front roof bars
DBR9
You need an account to view it.
RedMist
Postby Infinite » Sat Aug 04, 2007 7:18 pm
its so bueatyful ill repost it!
Lots
Infinite
Postby Mr Revhead » Sat Aug 04, 2007 7:39 pm
DBR9
really? i hadnt logged in to get that....
Postby Leon » Sat Aug 04, 2007 7:41 pm
Mr Revhead wrote:thats not the article i was reffering too, the one i saw was in the MSNZ mag i think
.... and what do you think I was linking to, by a link to the MSNZ website ... ;)
Postby Infinite » Sat Aug 04, 2007 7:44 pm
so bring the front roll bars down the front pillers? and then just say drop them down just at the opening for the door? witch would kill the dash?
correct?
Lots
Infinite
Postby Mr Revhead » Sat Aug 04, 2007 7:44 pm
i read it... its not the one i was reffering to.
Postby RedMist » Sat Aug 04, 2007 7:56 pm
Infinite wrote:so bring the front roll bars down the front pillers? and then just say drop them down just at the opening for the door? witch would kill the dash?
correct?
No, either exactly the same as the DBR9 or the same as mine with the small bar between the two door braces pointing more towards the front foot.
RedMist
Postby Infinite » Sat Aug 04, 2007 8:02 pm
so like this :( hope im right this time!
ignore the red!!!
Lots
Infinite
Postby RedMist » Sat Aug 04, 2007 8:21 pm
Simply remove the link between the two crossmembers and direct it more towards the foot.
Or this
RedMist
Postby strx7 » Sat Aug 04, 2007 8:30 pm
RedMist wrote:You must be near sitting in the boot! The struggle I have had to get to fit in the Celica is monumental! And I'm only 6'1"..... Another thing to watch with the Celica and I supect Curren is the seat height. You cant get anywhere near seeing the front corners but seeing as much of the bonnet as possible is advantageous.
if you think that is challenging, try adding to the mix that i want my GF to be able to drive the car too and she's only 1.73m ............... argh
Postby Infinite » Sat Aug 04, 2007 11:23 pm
ok re reading what u have said about the bar going to the front foot i now understand i had it confused :P
Lots
Infinite
Postby Infinite » Sun Aug 05, 2007 9:37 pm
on 38.1x2.5mm steel cage tube what is the max ammount the bend is allowed to crumble by?
"In selecting material attention must be paid to
obtaining good elongation properties and
adequate weldability. The tubing must be bent
by a cold working process and the centre-line
bend radius must be at least 3 times that of the
tube diameter.
If the tubing is ovalised during bending, the
ratio of minor to major diameter must be 0.9
or greater."
dont understand the last bit and thats ovalised not crushed in a wee bit on like the inner?
Lots
Infinite
Postby 85AW20v » Sun Aug 05, 2007 11:16 pm
Ovalised as in no longer round so the tube can be distorted either way. For ease of maths, if your tube was 100mm diameter and was crushed a bit in the bending process, the minimum measurement it can be is 90mm.
See ya
Simon
85 MR2 20v
85AW20v
