4agze goes chuff??
Postby pjay » Sun Aug 12, 2007 11:15 pm
method wrote:I always bridge it at the ECU.
You just need to earth T.
(E1 stands for earth)
that sounds good. is the ECU under the stereo area?
pjay
Postby Mr Revhead » Sun Aug 12, 2007 11:16 pm
yes.
but its a PITA to get to the plug
and you to know what pin it is
Postby pjay » Sun Aug 12, 2007 11:22 pm
bugger.. ill save it for tomorrow. did a google, but theres limited info on 4agze ecus :?
pjay
Postby rollaholic » Sun Aug 12, 2007 11:31 pm
http://www.club4ag.com/technical_main.h ... and%20Data
toyota ecu pinouts n stuff.
great resource!
Postby pjay » Sun Aug 12, 2007 11:35 pm
excellent! :D ill be up bright and early to check it before work
Thanks!
pjay
Postby IH8TEC » Mon Aug 13, 2007 8:12 am
you say you put a pipe to a cold air box, what kind of pipe is it? possibly it's just collapsing, unless it's a metal pipe?
Postby pjay » Mon Aug 13, 2007 9:17 am
IH8TEC wrote:you say you put a pipe to a cold air box, what kind of pipe is it? possibly it's just collapsing, unless it's a metal pipe?
2.5" to 3" silicone --> Aluminum 3" 45degree bend pipe --> 3" to 2.5" silicone --> 2.5" mild steel straight pipe --> 2.5" to 3" silicone --> airbox and pod filter
pics ftw:
before: Image After Image [img]
pjay
Postby IH8TEC » Mon Aug 13, 2007 10:18 am
scrap my idea then :D
Postby pjay » Mon Aug 13, 2007 11:25 am
:) sweet as. its a sexy box ay! alls i need is shiny extractors and im set :lol:
pjay
Postby frost » Mon Aug 13, 2007 1:25 pm
wow thats a sexy box :lol:
Postby evil_si » Mon Aug 13, 2007 2:50 pm
how did u earth the battery? did u run a cable from the battery to the engine?
or did you earth the battery were it sits in the boot to the chassis, and earth the engine to the chassis?
evil_si
Postby pjay » Mon Aug 13, 2007 4:02 pm
evil_si wrote:how did u earth the battery? did u run a cable from the battery to the engine?
Earth the engine? I earthed the battery to the chassis in the boot... but i never touched any engine earths to my knowledge
pjay
Postby IH8TEC » Mon Aug 13, 2007 4:13 pm
run an earth from the battery to the engine as well.
Postby pjay » Mon Aug 13, 2007 4:41 pm
IH8TEC wrote:run an earth from the battery to the engine as well.
from where on the engine??
pjay
Postby no_8wire » Mon Aug 13, 2007 6:42 pm
Just anywhere on the block...
no_8wire
Postby themaleman » Mon Aug 13, 2007 7:48 pm
i got a fat earth going from the battery in the boot straight 2 the gearbox, neva had this problem, the line to my map sensor came unpluged once and the car woud just die on boost, ran sweet up 2 0 psi but once u went past that it lost all power, check ya line coming from the intake to the map sensor, should b on the right of ya intake
manual 80 series cruiser
4agte ae92 Levin
a15 powered sj410
themaleman
Postby Alex B » Mon Aug 13, 2007 8:04 pm
If you have a good earth to chassie and a good earth for chassie to engine thenn you shouldnt need to. And try check the codes again, just make sure you have the paper clip in there goodly. Dont remove the gunk thats in there. It stops the plug from rusting up.
Postby pjay » Mon Aug 13, 2007 8:39 pm
themaleman wrote:check ya line coming from the intake to the map sensor, should b on the right of ya intake
Took the car to Joes mechanical off Hendo valley. Nice nice guy!! I would recommend him to my mother!
neither of us could find the map sensor!! Where is it located exactly?
pyro_sniper2002 wrote:If you have a good earth to chassie and a good earth for chassie to engine thenn you shouldnt need to. And try check the codes again, just make sure you have the paper clip in there goodly. Dont remove the gunk thats in there. It stops the plug from rusting up
He reckons its either an ECU short, OR my MAP sensor is flooded with oil. Im going to earth "T1" at the ECU itself to see if it will diagnose because his scanner wouldnt communicate with the ECU.. just jumping on the net now to grab a wiring diagram of the gze ecu
pjay
Postby Alex B » Mon Aug 13, 2007 8:51 pm
I had a friend with an AE101 Marino 20V, that stuffed the ecu. Does exactly as you discribe. Its most likley to old to work with a scan tool. My MR2 doesnt work with the old mans Snap on one. And the MAP should be on the firewall and called vacume array sensor or manifold pressue assembly possibly.
Postby pjay » Mon Aug 13, 2007 8:58 pm
pyro_sniper2002 wrote:And the MAP should be on the firewall and called vacume array sensor or manifold pressue assembly possibly.
Well thats what i thought!! Ill take a pic o/ the firewall and post it up in 5 mins
pjay
Users browsing this forum: No registered users and 30 guests
