by rollaholic » Mon Sep 03, 2007 9:36 pm
oil pump seal and crank seal are two different things also
theres no reason you couldnt do it if you have someone who knows a bit about it nearby to check how you are doing things, but its easy to get it wrong if you dont know how to do it, and theres alot of time involved each way - putting it all back together then taking it apart again when you realise the timing is a tooth out or something.
theres also potential to seriously damage engine if you try and start it with cambelt belt incorrectly tensioned etc
