4age going very slow
Postby rollaholic » Mon Oct 08, 2007 6:00 pm
check cam timing, make sure keyway hasn't crapped itself.
Postby rwd_mayhem » Mon Oct 08, 2007 6:58 pm
bluemaumau wrote:http://forums.toyspeed.org.nz/viewtopic.php?t=29042
that doesn't answer my question.......... :roll:
current: 1975 Valiant Regel
previous: 1980 mazda 626, 4AGE AE70 sedan, AE70 sedan, mk2 escort, KP60 starlet, TE71 liftback X2
rwd_mayhem
Postby bluemaumau » Mon Oct 08, 2007 7:12 pm
put the size feller guage between the acc cable thingy and stop then check resistances :roll:
Postby rwd_mayhem » Mon Oct 08, 2007 7:18 pm
rwd_mayhem wrote:how do u set tps?
when i put it on where do the prongs line up to?
when i turn it should it turn the throttle body butterfly? or just spin easily?
rwd_mayhem
Postby rwd_mayhem » Wed Oct 10, 2007 3:56 pm
it was the keyway! been completely destroyed! all going good now after putting a new one in.
it was nearly impossible to find them i went all around town looking for who kept them, ended up going to blacks getting one that was too big and grinded it down to the correct size.
rwd_mayhem
Postby rollaholic » Wed Oct 10, 2007 6:46 pm
i win this thread!
Postby matt dunn » Wed Oct 10, 2007 7:40 pm
rollaholic wrote:i win this thread!
Really,
i thought that a key way problem would put the cam timing out like I said???
lol
(Who cares)
Postby rollaholic » Wed Oct 10, 2007 8:23 pm
rollaholic wrote:check cam timing, make sure keyway hasn't crapped itself.
i said what you said, and told him WHY the timing would be out :P
Postby rwd_mayhem » Wed Oct 10, 2007 9:34 pm
apparently its a common problem with 4ages. pretty easy fix in the end which i like lol
rwd_mayhem
Postby Crucible » Wed Oct 10, 2007 10:08 pm
Really,
lol
(Who cares)
classic case of why I dont bother helping much anymore LOL.
People dont listen, so why bother. :P
Crucible
Real Life Mechanic
Postby pc » Thu Oct 11, 2007 9:31 am
rwd_mayhem wrote:apparently its a common problem with 4ages. pretty easy fix in the end which i like lol
I think it is only a 'common problem' if the crank pulley bolt isn't torqued up correctly... and NOT an easy fix if the slot in the crank is buggered.
red car
1/4 mile - 14.683s @ 91.83mph
Manfield - 1:24s
pc
Postby ollieboy » Thu Oct 11, 2007 11:17 pm
pc wrote:I think it is only a 'common problem' if the crank pulley bolt isn't torqued up correctly... and NOT an easy fix if the slot in the crank is buggered.
As in too tight or too loose? Or both? Just I will be tightening one next week and would like to know. :)
ollieboy
