bluemaumau wrote:http://forums.toyspeed.org.nz/viewtopic.php?t=29042
rwd_mayhem wrote:how do u set tps?
when i put it on where do the prongs line up to?
when i turn it should it turn the throttle body butterfly? or just spin easily?
rollaholic wrote:i win this thread!
rollaholic wrote:check cam timing, make sure keyway hasn't crapped itself.
matt dunn wrote:rollaholic wrote:i win this thread!
Really,
i thought that a key way problem would put the cam timing out like I said???
lol
(Who cares)
rwd_mayhem wrote:apparently its a common problem with 4ages. pretty easy fix in the end which i like lol
pc wrote:I think it is only a 'common problem' if the crank pulley bolt isn't torqued up correctly... and NOT an easy fix if the slot in the crank is buggered.
Users browsing this forum: Bing [Bot] and 18 guests
