sw20 check engine light
Postby diss7 » Fri Feb 08, 2008 3:17 pm
FXGTV wrote:If anyone has a photo of exactly where the sensor is it would be appreciated. I'm having trouble finding it as i dont have access to any ramps or proper jacks at the moment. Its hard to look around when your 1cm away from burning your nose off on the exhaust :P
Tip for the day : Wait till car is cool
diss7
Postby FXGTV » Fri Feb 08, 2008 3:20 pm
Haven't you heard? An mr2 never cools down :P Im pretty sure ive located it now anyway...the hard part is working out how the feck im going to get to it! You name it and it's in the way!
1988 r31 TI Skyline.
FXGTV
Postby fivebob » Fri Feb 08, 2008 3:24 pm
FXGTV wrote:Im pretty sure ive located it now anyway...the hard part is working out how the feck im going to get to it! You name it and it's in the way!
Deep 30mm socket, and an appropriate extension (preferably the wobble drive type) ;)
Postby FXGTV » Fri Feb 08, 2008 3:28 pm
Haha i hear that! Just wating on the ramps now - thanks for the help guys. At least when this happens to another newb they will have a FAQ to look at 8) BTW, the second hand sensor cost me $75 from Hillside auto wreckers in Upper Hutt. They still have another one if anyone else needs one.
FXGTV
Postby Boosted_162 » Fri Feb 08, 2008 4:51 pm
An MR2 knock sensor is much easier to get to than a GT4 one! Heres a pic anyway, got mine on ramps at the moment :)
Its the sensor smack bang in the middle.
Postby FXGTV » Fri Feb 08, 2008 5:05 pm
Cheers for that one mate. At first i thouht i wud have to navigate the gap between the exhaust and the all the suspension crap - but with a little lateral thinking i just out my hand up through the relatively big gap by the transmission :o :roll: :twisted:
FXGTV
Postby FXGTV » Sat Feb 09, 2008 1:47 pm
Right, all sorted. I got the new knock sensor in withouit a hassle. The old one was starting to corrode, so it's a good thing I got it out before it fused itself to the block :P
The error codes are still comming up (34 and 52), even after I reset the ecu and disconnected the negative terminal. Its boosting normally and running sweet as though :) What else can I do to get rid of the stored error codes?
FXGTV
Postby Boosted_162 » Sat Feb 09, 2008 2:07 pm
Try pulling the EFI fuse i think it is. Pulling it resets it afaik.
Postby fivebob » Sat Feb 09, 2008 2:08 pm
And leave it out, or disconnect the battery, for at least 30 seconds
Postby FXGTV » Sat Feb 09, 2008 3:03 pm
Sweet as - that did the trick :) The weird thing is the speedo read exactly, and I mean exactly, 155,000k when I replaced the sensor. The car must have known something :lol:
FXGTV
