Custom Airbox
Postby NZVengeance » Tue Feb 12, 2008 11:55 am
looks interesting will have to have a look once im home tonight.
Only two things are infinite, the universe and human stupidity, and I'm not sure about the former.
Albert Einstein
He who dies with the most Toys wins!!
NZVengeance
Postby barryogen » Tue Feb 12, 2008 1:29 pm
essencially it is used to just keep a more stable intake temp... it doesn't cool it much, but is handy to keep it consistant.
Finding a place to keep them that would remain under 50c could be tricky in an engine bay though...
MR2 you could put it on top of the engine bay and it would probably get adequate air flow, but on a front engined car putting the IC on the bonnet would probably get some interesting looks :)
barryogen
2ZZ Guru in training
Postby NZVengeance » Tue Feb 12, 2008 1:38 pm
well another good way to drop intake temp is a water/methanol injection system.
Albert Einstein
NZVengeance
Postby Crampy » Tue Feb 12, 2008 2:30 pm
The best thing for your car is a new computer. That way you can tune it for any other changes in the future. It'll go much better with just the computer too.
Crampy
Postby Prymal » Tue Feb 12, 2008 5:50 pm
you already have a factory intercooler spraybar AND water injection . Just find means and ways of enabling them , and youll have similar effect ..
Prymal
Postby NZVengeance » Tue Feb 12, 2008 9:05 pm
water injection??? i wasnt aware that wrc's had water injection?
where is it? where is the tank it gets its water from?
i know about the IC sprayers
Albert Einstein
NZVengeance
Postby gmacrae » Wed Feb 13, 2008 5:00 pm
those peltiers will need to be cooled or your car will go up in flames lol. Plus they would need some kind of heat exchanger core to actually cool the intake charge, plus they'll use a fair bit of power if you want some to make a decent drop in temp.
that parrifin wax thing is interesting, but no good on an n/a car as its only going to do its job above 50degrees (n/a intake should never get much hotter than ambient) - there's definitely some potential there for forced induction though, pretty cool stuff.
gmacrae
Postby barryogen » Wed Feb 13, 2008 5:08 pm
gmacrae wrote:there's definitely some potential there for forced induction though, pretty cool stuff.
I think that the main issue would be where to put it, to keep it below 50c ambient... in the engine bay would likely be too hot, and moving it out of the engine bay, you begin to lose the advantages of having short pipe length, simplicity etc, and so you may aswell go FMIC
barryogen
Postby NZVengeance » Wed Feb 13, 2008 6:41 pm
classique71 you said they had water injection ive never heard of them having this?
Albert Einstein
NZVengeance
Postby Infinite » Wed Feb 13, 2008 7:03 pm
they have water injection its the two valves below the intake manifold isnt it?, your coming up with some crazy shit dude? u smoking p?
Lots
Infinite
Postby fangsport » Wed Feb 13, 2008 8:42 pm
Infinite wrote:your coming up with some crazy sh*t dude? u smoking p?
or some friggin' sticky hydro.
fangsport
Postby Lloyd » Wed Feb 13, 2008 9:05 pm
You are looking at the complete wrong side of things. There is no real point cooling the air before the turbo in the first place, the turbo puts a lot of heat into the air via compression. Look at cooling after. In which case just get a decent intercooler, water-to-air setup or an ice box.
Postby ChaosAD » Wed Feb 13, 2008 10:41 pm
could use a couple of those 12v chillybin coolers :) dnt think they very efficient though
ChaosAD
Postby NZVengeance » Thu Feb 14, 2008 8:13 am
no none of that just an active imagination.
it never huts to come up with new and interesting ideas even if they dont work.
Albert Einstein
NZVengeance
Users browsing this forum: No registered users and 33 guests
